Order Now
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
In stock
In stock
Limited stock
Limited stock
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Unit Price$164.90$158.30$148.40$141.80
Limited stock
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Unit Price$137.90$132.35$124.10$118.60
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Unit Price$174.30$167.35$156.90$149.90
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB Flash, 10/100 Mbit Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Unit Price$124.45$119.45$112.00$107.05
Limited stock
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB Flash, 10/100 Mbit Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Unit Price$151.90$145.80$136.70$130.65
In stock
Unit Price$90.85$87.20$81.75$78.10
In stock
NXP® i.MX 6DualLite, 2x Arm Cortex™-A9, 800 MHz , 512MB DDR3 (64 Bit), 4GB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Unit Price$102.15$98.05$91.95$87.85
In stock
Unit Price$79.80$76.60$71.85$68.65
In stock
NXP® i.MX 6Solo, 1x Arm Cortex™-A9, 800 MHz , 256MB DDR3 (32 Bit), 4GB Flash, 10/100 Mbit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Unit Price$89.50$85.95$80.55$77.00
Limited stock
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB Flash, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to +85° C Temp. Range, Availability until 2027
Unit Price$71.65$68.75$64.50$61.60
In stock
