NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 4GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2036+
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with AVB Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
