NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR2 (32 Bit), 1GB SLC NAND, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
NVIDIA® Tegra™ 2, 2x Arm Cortex™-A9, 1.0 GHz, 256MB DDR2 (32 Bit), 512MB SLC NAND, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to 85° C Temp. Range, Availability until 2027
NXP® Vybrid™ VF6XX, 1x Arm Cortex™-A5, 500 MHz (A5), 167 MHz (M4), 256MB DDR3 (16 Bit) (or 128MB with ECC), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2028
NXP® Vybrid™ VF5XX, Arm Cortex™-A5, 400 MHz, 128MB DDR3 (16 Bit), 128MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2028
