NVIDIA® Tegra™ 3, 1x Arm Cortex™-A9, Up to 1.4 GHz, 2GB DDR3L (32 Bit), 10/100/1000 Mbit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to 85° C Temp. Range, Availability until 2025
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 800 MHz, 2GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to 85° C Temp. Range, Availability until 2036
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 1.0 GHz, 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2036
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 800 MHz, 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to 85° C Temp. Range, Availability until 2036
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2036
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, 10/100 Mbit Ethernet, -40° to 85° C Temp. Range, Availability until 2025
