NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with AVB Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.8 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 4GB eMMC, Gigabit with AVB Ethernet, 0° to 70° C Temp. Range, Availability until 2035+
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 4GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2036+
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB-C (DualRole), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 98x GPIOs
Physical: 7-24V DC ±10% Supply Voltage, Size: 250mm x 200mm
Physical: 5-24V DC ±10% or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
Connectivity: USB 3.0: 1x USB-A (Host), USB 2.0: 1x USB-A (Host), 1x USB-C (DualRole), 1x Gigabit Ethernet, 2x I2C, 1x SPI, 2x PWM, 4x ADC, 1x Via transceiver/ 1x On extension connector CAN, 31x GPIOs
Multimedia:
Physical: 8-25V DC ±10% Supply Voltage, Size: 120mm x 120mm
