Order Now
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2035+
Unit Price$131.40$126.15$118.30$113.05
In stock
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40°C to +85°C Temp. Range, Availability until 2035+
Unit Price$113.10$108.60$101.80$97.25
Limited stock
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2035+
Unit Price$111.35$106.90$100.20$95.75
Limited stock
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.8 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 4GB Flash, Gigabit with AVB Ethernet, 0° to +70° C Temp. Range, Availability until 2035+
Unit Price$78.80$75.65$70.90$67.75
Limited stock
