Order Now
Results: 1-17 of 17 products.
Sort By
  View
V1.1B
Apalis iMX8QM
Product Change Notification
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $283.20
    $271.90
    $254.90
    $243.60
In stock
V1.1B
Apalis iMX8QM
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $263.15
    $252.65
    $236.85
    $226.35
In stock
V1.0B
Apalis iMX8QM
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $241.05
    $231.40
    $216.95
    $207.30
Limited stock
V1.1B
Apalis iMX8QM
In Development
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $220.75
    $211.90
    $198.65
    $189.85
Coming soon
Get Updates
V1.2A
Apalis TK1 2GB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $249.90
    $239.90
    $224.90
    $214.90
Limited stock
V1.1A
Apalis T30 2GB
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $185.50
    $178.10
    $166.95
    $159.55
Limited stock
V1.1B
Apalis T30 2GB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $185.50
    $178.10
    $166.95
    $159.55
Limited stock
V1.1A
Apalis T30 1GB
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $167.90
    $161.15
    $151.10
    $144.40
In stock
V1.1B
Apalis T30 1GB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $167.90
    $161.15
    $151.10
    $144.40
Limited stock
V1.1B
Apalis T30 1GB IT
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $188.90
    $181.35
    $170.00
    $162.45
Limited stock
V1.1C
Apalis iMX6 Quad 2GB IT
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $153.70
    $147.55
    $138.35
    $132.20
In stock
V1.1B
Apalis iMX6 Quad 1GB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $125.65
    $120.60
    $113.10
    $108.05
In stock
V1.1B
Apalis iMX6 Dual 1GB IT
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $131.65
    $126.35
    $118.50
    $113.20
Limited stock
V1.1B
Apalis iMX6 Dual 512MB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $112.05
    $107.60
    $100.85
    $96.40
Limited stock
V1.1A
Ixora Carrier Board 1.1A
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.2A
Ixora Carrier Board V1.2A
Sample Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.1C
Apalis Evaluation Board V1.1C
Evaluation Product
  • Quantity
    >0
  • Unit Price
    $245.00
In stock
Have a Question?
