Order Now
Results: 1-7 of 7 products.
Sort By
  View
V1.1B
Apalis iMX8QM
PN: 00371101
Product Change Notification
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $283.20
    $271.90
    $254.90
    $243.60
Limited stock
V1.0B
Apalis iMX8QM
PN: 00481001
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $241.05
    $231.40
    $216.95
    $207.30
Limited stock
V1.1B
Apalis iMX8QXP Front
PN: 00461101
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $190.80
    $183.20
    $171.75
    $164.10
Coming soon
Get Updates
V1.0B
PN: 00551001
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $131.40
    $126.15
    $118.30
    $113.05
(1)The Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Verdin iMX8M Mini 2GB WB IT is still listed as an Industrial Temperature product.
Limited stock
V1.1A
Verdin iMX8M Mini DualLite 1GB  Wi-Fi / Bluetooth IT
PN: 00601100
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB Flash, Gigabit with AVB Ethernet, -40°C to 85°C Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.35
    $106.90
    $100.20
    $95.75
Coming soon
Get Updates
V1.0D
Colibri iMX8X Front
PN: 00381003
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $166.10
    $159.45
    $149.50
    $142.85
Limited stock
V1.0D
Colibri iMX8X Front
PN: 00511003
NXP® i.MX 8DualX, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB LPDDR4 (16 Bit), 4GB Flash, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $136.25
    $130.80
    $122.60
    $117.15
Limited stock
Have a Question?
