Order Now
Results: 1-6 of 6 products.
Sort By
  View
V1.1B
Apalis iMX8QXP Front
PN: 00461101
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $190.80
    $183.20
    $171.75
    $164.10
Coming soon
Get Updates
V1.1B
PN: 00531101
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $185.40
    $177.95
    $166.85
    $159.45
Coming soon
Get Updates
V1.1B
PN: 00541101
In Development
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $130.45
    $125.25
    $117.40
    $112.20
Coming soon
Get Updates
V1.1A
Ixora Carrier Board 1.1A
PN: 01331100
Product Change Notification
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.2A
Ixora Carrier Board V1.2A
PN: 01331200
Sample Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.1C
Apalis Evaluation Board V1.1C
PN: 01151102
Evaluation Product
  • Quantity
    >0
  • Unit Price
    $245.00
In stock
Have a Question?
