Order Now
Results: 1-8 of 8 products.
Sort By
  View
V1.1A
Apalis iMX8QM
PN: 00671100
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 8GB LPDDR4 (64 bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2034+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $375.00
    $360.00
    $337.50
    $322.50
Intended Use: For End Products
V1.1E
Apalis iMX8QM
PN: 00371104
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2034+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $324.85
    $311.85
    $292.35
    $279.35
V1.1D
Apalis iMX8QM
PN: 00471103
Volume Production
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2034+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $299.90
    $287.90
    $269.90
    $257.90
V1.1D
Apalis iMX8QM
PN: 00481103
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 2GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -25° to 85° C Temp. Range, Availability until 2034+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $268.75
    $258.00
    $241.90
    $231.15
V1.1D
Apalis iMX8QM
PN: 00491103
Volume Production
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $243.45
    $233.75
    $219.15
    $209.40
V1.2A
Volume Production
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $131.25
    $126.00
    $118.15
    $112.90
V1.3A
Ixora Carrier Board V1.3A
PN: 01331300
Sample Production
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $131.25
    $126.00
    $118.15
    $112.90
V1.1Z
Apalis Evaluation Board V1.1Z
PN: 01151125
Sample Production
  • Quantity
    >0
  • Unit Price
    $325.00
Intended Use: For Evaluation/Development
Have a Question?
