Order Now
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
Unit Price$131.40$126.15$118.30$113.05
Limited stock
Unit Price$113.10$108.60$101.80$97.25
Coming soon
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB Flash, Gigabit with AVB Ethernet, -40°C to 85°C Temp. Range, Availability until 2030+
Unit Price$111.35$106.90$100.20$95.75
Coming soon
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.8 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 4GB Flash, Gigabit with AVB Ethernet, 0° to +70° C Temp. Range, Availability until 2030+
Unit Price$78.80$75.65$70.90$67.75
Coming soon
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB Micro-B (OTG), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 109x GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out.
Physical: 6-27V DC Supply Voltage, Size: 250mm x 200mm
Quantity>0
Unit Price$318.00
Limited stock
Physical: 5-27V DC or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
Quantity>0
Unit Price$148.90
Limited stock
0° to +70° C Temp, Range. Size: 50 x 40 mm.
Quantity>0
Unit Price$32.50
Limited stock
