NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2035+
