You've Selected
Narrow Results
Browse Products
At Toradex, your product vision becomes an affordable and immediate reality!
Using a Computer on Module (CoM) or Customized Single Board Computers (SBC) offers flexibility to system developers to focus on their application development by using an off-the-shelf product which has generic hardware and comes with production-ready software to kick start the development of a variety application. This approach greatly reduces the time-to-market and your development cost.
Results: 1-15 of 42 products.
  View
You can choose up to 10 products for comparison
Compare 0 Products
Apalis iMX8QM
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6GHz (A72) , 1.26GHz (A53) , 266MHz (M4)
640 MHz (DSP), 4GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
Apalis iMX8QM
640 MHz (DSP), 4GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Apalis iMX8QM
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6GHz (A72) , 1.26GHz (A53) , 266MHz (M4), 2GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Apalis iMX8QM
Apalis TK1 2GB
NOTE: Apalis Heatsink Type 3 required.
NVIDIA® Tegra™ K1, NXP® Kinetis™ K20 Companion MCU, 4x Arm Cortex™-A15, Up to 2.1 GHz (A15), 100 MHz (M4), 2GB DDR3L (64 Bit), 16GB eMMC, Gigabit with IEEE 1588 Ethernet, -25° to +85° C Temp. Range, Availability until 2025
Apalis iMX8X is currently in development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB DDR3L (32 Bit), 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB DDR3L (32 Bit) with ECC, 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
NXP® i.MX 8DualXPlus, 2x Arm Cortex™-A35, 1.2GHz (A35), 266MHz (M4), 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Apalis T30 2GB
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 2GB DDR3L (32 Bit), 8GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Apalis T30 1GB
NVIDIA® Tegra™ 3, Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC (8 Bit), Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Apalis T30 1GB IT
NVIDIA® Tegra™ 3, 4x Arm Cortex™-A9, Up to 1.4 GHz, 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Apalis iMX6 Quad 2GB IT
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 800 MHz , 2GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Apalis iMX6 Quad 1GB
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 1.0 GHz, 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
Apalis iMX6 Dual 1GB IT
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 800 MHz , 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Apalis iMX6 Dual 512MB
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
Compare 0 Products
