This display is directly compatible with the Apalis SoM Family.
Highlights
Out-of-the-Box Experience with Toradex Carrier Boards
It works with the following Toradex Carrier Boards out-of-the-box:
Scope of delivery
- 10.1” Capacitive Touch Display Panel
- LVDS cable
- 10 Pins 0.5mm FFC Ribbon Cable
Carrier Boards
Learn more about SBCs and Carrier BoardsBuy Now
Capacitive Touch Displays (LVDS) for Apalis modules
LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it with a Carrier Board. -20° to 70° C Temp, Range. Size: 248.5 x 166.1 x 15.0 mm.
Quantity>0
Unit Price$258.00
Quantity1-99>99
Unit Price$134.40
Quantity>0
Unit Price$349.40
Quantity1-99>99
Unit Price$79.95
