NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
