Wi-Fi / Bluetooth Starter Kit
Get started with your own IoT application right away!
This kit provides you the perfect set-up to get started with your IoT application right away. The Colibri iMX6ULL with on-board Wi-Fi / Bluetooth combined with the Aster Carrier Board, an Antenna and the multi-socket power supply allow you to get started right away completely out-of-the-box.
Getting Started
You can make use of our step-by-step Getting Started Guide to get started with your application easily.
Useful links
  • NXP® i.MX 6ULL
  • 1x Arm Cortex™-A7
  • 800 MHz
  • 512MB DDR3L (16 Bit)
  • 512MB SLC NAND
  • -40° to +85° C(2) Temp
  • USB 2.0: 2x Host, 1x Client (Shared)
  • 10/100 Mbit Ethernet
  • Size: 100 x 80 mm
  • Supports frequency of 2.4 and 5 GHz
  • Includes antenna and MHF4 connector cable
Single Unit Price
US$ 155,20
US$ 99,00
Compra Agora
