Você escolheu
Buscar
Filtrar
Cotação
Atenção para falta de componentes na indústria eletrônica durante o ano de 2017
Resultados: 1-15 de 61 produtos.
Ordenar por
Visualizar
Apalis TK1 2GB | V1.1A
Sample Product
NVIDIA® Tegra™ K1
NXP® Kinetis™ K20 Companion MCU, ARM Cortex™-A15
Cortex™-M4 (Companion MCU), Up to 2.1 GHz (A15)
100 MHz (M4), Quad Core (A15)
Heteregenous (M4 Companion MCU), 2GB DDR3L (64 Bit), 16GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -25° to +85° C Temp. Range, Availability until 2025
Quantidade
Preço unitário
1-99100-249250-499500-999≥1000
US$236,60US$231,90US$217,70US$203,50RFQ
in stock
NXP® i.MX 8QuadMax, ARM Cortex™-A72, Cortex™-A53, Cortex™-M4, 1.6GHz (A72), 1.2GHz (A53), 266MHz (M4), Dual Core (A72), Quad Core (A53), Dual Core (M4), 4GB LPDDR4 (2x 32-bit), 16GB eMMC (8bit), 10/100/1000 Mbit IEEE1588 Ethernet, -25* to +85° C Temp. Range, Availability until 2030
coming soon
Apalis T30 2GB | V1.1A
Volume Product
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 2GB DDR3L (32 Bit), 8GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Quantidade
Preço unitário
US$175,55US$168,55US$158,00US$151,00RFQ
in stock
Apalis T30 1GB | V1.1A
Product Change Notification
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 1GB DDR3L (32 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
Quantidade
Preço unitário
US$163,60US$157,05US$147,25US$140,70RFQ
in stock
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 1GB DDR3L (32 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2025
Quantidade
Preço unitário
US$179,95US$172,80US$162,00US$154,80RFQ
in stock
Sample Product
Quantidade
Preço unitário
low stock
Volume Product
NXP®/Freescale i.MX 6Quad, ARM Cortex™-A9, 800 MHz, Quad Core, 2GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Quantidade
Preço unitário
US$153,70US$147,55US$138,30US$132,20RFQ
in stock
Volume Product
NXP®/Freescale i.MX 6Quad, ARM Cortex™-A9, 1.0 GHz, Quad Core, 1GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
Quantidade
Preço unitário
US$125,65US$120,60US$113,05US$108,05RFQ
in stock
Sample Product
NXP®/Freescale i.MX 6Dual, ARM Cortex™-A9, 800 MHz, Dual Core, 1GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
Quantidade
Preço unitário
US$131,65US$126,35US$118,45US$113,20RFQ
low stock
NXP®/Freescale i.MX 6Dual, ARM Cortex™-A9, 1.0 GHz, Dual Core, 512MB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
Quantidade
Preço unitário
US$112,05US$107,60US$100,85US$96,40RFQ
in stock
Volume Product
Quantidade
Preço unitário
low stock
Volume Product
Small form-factor Apalis ARM Computer Module family Carrier Board
Connectivity: USB 3.0: 2x Host, USB: 1x Host (High Speed)
1x OTG (High Speed), 10/100/1000 Mbit Ethernet, 2x I2C, 1x SPI, 4x PWM, 4x ADC, 2x CAN, 2x LEDs, up to 40 GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out, 1x Camera Parallel Interface, 4/5-wire Resistive Touch
Physical: 7-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 125 x 90 mm
Quantidade
Preço unitário
US$99,70US$94,10US$91,85US$89,60RFQ
in stock
Evaluation Product
Connectivity: USB 3.0: 1x Host, 1x OTG, USB: 4x Host (High Speed), 10/100/1000 Mbit Ethernet, 3x I2C, 2x SPI, 4x PWM, 4x ADC, 2x CAN, 8x Switches, 8x LEDs, up to 135 GPIOs
3.3V 5A On-Board Power Supplies, Size: 250 x 250 mm
Quantidade
Preço unitário
1
US$229,00
in stock
Volume Product
Heatsink for Apalis iMX6Q IT and Apalis iMX6D IT modules
Compatible with Apalis iMX6Q IT and Apalis iMX6D IT, Contains the TIM (Thermal Interface Material) and 4 screws, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additonal threaded holes available for attaching fan to the carrier board.
Quantidade
Preço unitário
US$12,35US$11,20US$10,10US$9,00RFQ
in stock
Volume Product
Heatsink for Apalis T30 module
Compatible with Apalis T30, Contains the TIM (Thermal Interface Material) and 4 screws, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additonal threaded holes available for attaching fan to the carrier board.
Quantidade
Preço unitário
in stock
