Request Quote
Results: 1-13 of 13 products.
Sort By
  View
V1.1B
Apalis iMX8QM
Product Change Notification
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $283.20
    $271.90
    $254.90
    $243.60
Limited stock
V1.1B
Apalis iMX8QM
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $263.15
    $252.65
    $236.85
    $226.35
Limited stock
V1.0B
Apalis iMX8QM
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $241.05
    $231.40
    $216.95
    $207.30
Limited stock
V1.1B
Apalis iMX8QM
In Development
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $220.75
    $211.90
    $198.65
    $189.85
Coming soon
Get Updates
V1.2A
Apalis TK1 2GB
Volume Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $249.90
    $239.90
    $224.90
    $214.90
Limited stock
V1.1B
Apalis iMX8QXP Front
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 2GB DDR3L (32 Bit), 16GB Flash, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $190.80
    $183.20
    $171.75
    $164.10
Coming soon
Get Updates
V1.1B
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 2GB DDR3L (32 Bit) with ECC, 16GB Flash, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $185.40
    $177.95
    $166.85
    $159.45
Coming soon
Get Updates
V1.1B
In Development
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $130.45
    $125.25
    $117.40
    $112.20
Coming soon
Get Updates
V1.1A
Ixora Carrier Board 1.1A
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.2A
Ixora Carrier Board V1.2A
Sample Product
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $111.90
    $107.40
    $100.70
    $96.20
In stock
V1.1C
Apalis Evaluation Board V1.1C
Evaluation Product
  • Quantity
    >0
  • Unit Price
    $245.00
In stock
V1.0
Verdin Development Board with HDMI Adapter
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB Micro-B (OTG), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 109x GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out.
Physical: 6-27V DC Supply Voltage, Size: 250mm x 200mm
  • Quantity
    >0
  • Unit Price
    $318.00
Limited stock
V1.0
Dahlia Carrier Board with HDMI Adapter
Physical: 5-27V DC or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
  • Quantity
    >0
  • Unit Price
    $148.90
Limited stock
Have a Question?
