Partner Carrier Boards
Below are a selection of Third-party Carrier Boards & Display Assemblies compatible with Toradex System on Modules. These off-the-shelf products are available for development and volume production directly from the Third-party hardware vendors. Please contact hardware vendors directly for additional product information and purchasing instructions.
Have you used Hardware from our partners? We'd like to hear your experience.
Results: 1-6 of 6 Hardware partners.
  View
Connectivity:
4x USB, 4x Analog Input, 2x CAN, 2x 10/100/1000 MBit Ethernet, 16x GPIO, 2x I2C, 4x PWM, 1x Serial ATA, 2x SPI, 8x UART, 2x miniPCIe, 8x RS-422, 8x RS-485
Multimedia:
Analog Audio Line in, Camera Serial Interface, HDMI, LVDS, S/PDIF In / Out, VGA
Others:
102 x 146 - Size (in mm), Supply Voltage: 7-34V Input Range, -40°C to +85°C - Temperature Range (in Celsius)
Connectivity:
4x USB, 4x Analog Input, 1x 10/100/1000 MBit Ethernet, 8x GPIO, 2x I2C, 4x PWM, 2x SPI, 4x UART, 1x mSATA, 2x RS-422, 2x RS-485
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, Analog Audio Mic in, HDMI, LVDS, VGA
Others:
1x RTC on Board, 102 x 102 - Size (in mm), Supply Voltage: +5VDC, -40°C to +85°C - Temperature Range (in Celsius)
Connectivity:
2x RS485, 3x USB 2.0, 1x USB 2.0 Debug, 4x Analog Input, 2x CAN, 1x 10/100 MBit Ethernet, 26x GPIO, 1x I2C, 4x PWM, 1x SDIO/SD/MMC, 1x SPI, 1x UART, 1x miniPCIe
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, Analog Audio Mic in, Camera Parallel Interface, Capacitive Touch, Resistive Touch, RGB
Others:
1x RTC on Board, 95mm X 115mm - Size (in mm), Supply Voltage: 7VDC to 28VDC, -40C to +85C - Temperature Range (in Celsius), 2x USB-to-RS232 Transceiver
Connectivity:
3x USB, 11x 10/100/1000 MBit Ethernet
Multimedia:
HDMI
Others:
482 x 744 x 44 (WxLxH) including handles - Size (in mm), Supply Voltage: 110-230 AC
Connectivity:
3x USB, 2x 10/100/1000 MBit Ethernet
Multimedia:
HDMI
Others:
5x LEDs, 190 x 130 x 65 - Size (in mm), Supply Voltage: 12, 2x Switches, 1x USB-to-RS232 Transceiver
Connectivity:
2x USB 2.0, 4 x 12 Bit 4-20mA Analog Input, 4 x 12V DC - Digital Inputs, 4 x 12V DC 0.5A - Digital Outputs, 1x 10/100 MBit Ethernet, 1x I2C, 1x UART, 1x RS-485
Multimedia:
Compatible Accessories:
WiFi Module
Others:
5V 1A - On-Board Power Supplies (in Volts), 1x RTC on Board, 165 x 90 mm - Size (in mm), Supply Voltage: 12VDC 500mA, 0 - 70 °C - Temperature Range (in Celsius)
Have a Question?
