Partner Carrier Boards
Below are a selection of Third-party Carrier Boards & Display Assemblies compatible with Toradex System on Modules. These off-the-shelf products are available for development and volume production directly from the Third-party hardware vendors. Please contact hardware vendors directly for additional product information and purchasing instructions.
Have you used Hardware from our partners? We'd like to hear your experience.
Results: 16-21 of 21 Hardware partners.
  View
Connectivity:
2x USB, 1x 10/100 MBit Ethernet, 4x GPIO, 1x SDIO/SD/MMC, 1x SPI, 1x UART, 1x RS-485
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, Analog Audio Mic in, LVDS
Compatible Accessories:
Case, Display
Others:
100 x 72 - Size (in mm), Supply Voltage: 10 to 28V DC, -20°C to +65°C - Temperature Range (in Celsius)
Connectivity:
2x USB, 1x 10/100 MBit Ethernet, 1x SDIO/SD/MMC, 1x RS-422, 1x RS-485
Display, Touch
Others:
177.8 (7", 16:9), 264 (10.4", 4:3) , 381 (15", 4:3) - Size (in mm), Supply Voltage: 24V DC
Connectivity:
Display, Touch
Others:
Connectivity:
Display, Touch
Others:
Connectivity:
4x 4-20mA inputs, 2x USB 2.0, 4x ±32mV to ±32V inputs, 21 ranges, 1x 10/100/1000 MBit Ethernet
Multimedia:
HDMI
Others:
-40°C to +85°C - Temperature Range, 115 x 100 - Size (in mm), 9-30V power, EEPROM, Expansion connector: 1xUART, 1xI2C, 1xSPI, 6xGPIO, 2xAIN, 2XCAN, Micro SD Card Holder, On-board Cortex-M7 microcontroller, Optional plastic enclosure with DIN rail mount, RTC
Connectivity:
2x USB 2.0, 12x Analog Input, 2x 10/100/1000 MBit Ethernet, 2x CAN-FD (8Mbps), 1x LTE cellular connectivity using optional miniPCIe card, 2x RS-232, 2x RS-485
Multimedia:
HDMI
Others:
-40°C to +85°C - Temperature Range, 185 x 110 - Size (in mm), 9-30V power, Built-in power backup for 60 seconds, EEPROM, On-board Cortex-M7 microcontroller (480MHz), Optional metal enclosure with DIN rail mount, RTC
Have a Question?
