Partner Carrier Boards
Below are a selection of Third-party Carrier Boards & Display Assemblies compatible with Toradex System on Modules. These off-the-shelf products are available for development and volume production directly from the Third-party hardware vendors. Please contact hardware vendors directly for additional product information and purchasing instructions.
Have you used Hardware from our partners? We'd like to hear your experience.
Results: 1-6 of 6 Hardware partners.
  View
Connectivity:
2x USB, 1x Analog Input, 1x 10/100 MBit Ethernet, 24x GPIO, 1x I2C, 1x SDIO/SD/MMC, 1x SPI, 3x UART, 2x RS-422
Multimedia:
LVDS
Compatible Accessories:
Display, Touch
Others:
1x LEDs, 12v, 5v, 3.3v - On-Board Power Supplies (in Volts), 152.4 x 181 - Size (in mm), Supply Voltage: 9 to 36, 1x Switches, -40C to 60C - Temperature Range (in Celsius)
Connectivity:
1x USB, 1x Analog Input, 1x 10/100 MBit Ethernet, 4x GPIO, 1x I2C, 1x PWM, 1x SDIO/SD/MMC, 1x SPI, 2x UART
Multimedia:
Analog Audio Headphone out, Analog Audio Mic in, LVDS, Resistive Touch, RGB
Display, WiFi Module
Others:
2x LEDs, 1x RTC on Board, 150 x 100 x 12 - Size (in mm), Supply Voltage: 12 to 24V DC, 0°C to +50°C - Temperature Range (in Celsius)
Connectivity:
1x USB, 1x 10/100 MBit Ethernet, 4x GPIO, 1x I2C, 1x PWM, 1x SDIO/SD/MMC, 1x SPI, 2x UART
Multimedia:
Analog Audio Headphone out, Analog Audio Mic in, HDMI, LVDS, Resistive Touch, RGB, S/PDIF In / Out
Others:
2x LEDs, 1x RTC on Board, 130 x 140 x 14 - Size (in mm), Supply Voltage: 12 to 24V DC, 0°C to +50°C - Temperature Range (in Celsius)
Connectivity:
1x USB, Bluetooth, 1x 10/100 MBit Ethernet, 1x SDIO/SD/MMC, Wi-Fi
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, 2.5-Watt speaker driver with volume control, On-board Microphone
Others:
4x LEDs, 1x RTC on Board, Supply Voltage: 5V DC , 5x Switches
Connectivity:
1x USB, Bluetooth, 1x 10/100 MBit Ethernet, 20x GPIO, 1x I2C, 1x SDIO/SD/MMC, 1x SPI, Wi-Fi
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, HDMI, Resistive Touch
Display, Touch
Others:
1x RTC on Board
Connectivity:
2x RS485, 3x USB 2.0, 1x USB 2.0 Debug, 4x Analog Input, 2x CAN, 1x 10/100 MBit Ethernet, 26x GPIO, 1x I2C, 4x PWM, 1x SDIO/SD/MMC, 1x SPI, 1x UART, 1x miniPCIe
Multimedia:
Analog Audio Headphone out, Analog Audio Line in, Analog Audio Mic in, Camera Parallel Interface, Capacitive Touch, Resistive Touch, RGB
Others:
1x RTC on Board, 95mm X 115mm - Size (in mm), Supply Voltage: 7VDC to 28VDC, -40C to +85C - Temperature Range (in Celsius), 2x USB-to-RS232 Transceiver
Have a Question?
