This display is directly compatible with the Apalis SoM Family.
特色
Out-of-the-Box Experience with Toradex Carrier Boards
It works with the following Toradex Carrier Boards out-of-the-box:
Scope of delivery
- 10.1” Capacitive Touch Display Panel
- LVDS cable
- 10 Pins 0.5mm FFC Ribbon Cable
载板
立刻购买
Capacitive Touch Displays (LVDS) for Apalis modules
LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it with a Carrier Board. -20° to +70° C Temp, Range. Size: 248.5 x 166.1 x 15.0 mm.
数量>0
单价US$299.00
单价US$137.35US$131.90US$123.65US$118.15
数量>0
单价US$328.90
单价US$72.50US$69.60US$65.25US$62.35
