Apalis iMX8 Embedded Vision Starter Kit
Get started with Embedded Computer Vision and AI the easy way with fully industrial-grade hardware and software.
Apalis iMX8 Starter Kit
Blue Tick Mark
Industrial-grade SoM and Camera
Blue Tick Mark
Large Software Ecosystem
Blue Tick Mark
Long-term Availability
  • 12VDC 30W Power Supply
  • Lens
  • MIPI-CSI2 cable
  • Serial Port Adapter
  • USB to Serial Adapter
  • Apalis Heatsink Type 4
  • Alvium to Ixora adapter board
  • Null Modem Cable
  • Fan (with screws)
Cloud Connected On-Device AI Vision with
AWS IoT Greengrass and Amazon SageMaker Neo
With a few simple clicks, you can deploy a full end-to-end reference implementation of a device with an optimized neural network that can detect different kinds of pasta. The device is connected to the AWS Cloud via AWS IoT Greengrass. This allows the device to work even without connectivity.
A local User Interface (UI) via an HDMI screen gives you immediate feedback.
This will be automatically setup for you in just a few steps and will provide you with a Web-based user interface for remote monitoring and user management via Amazon Cognito.
Key Technologies
  • AWS IoT Greengrass
  • Amazon SageMaker Neo
  • Torizon
  • Docker
  • Amazon Congnito
  • MQTT
  • AWS IoT Core
Cloud-enabled AI Demo
Get Started
