您已经选择
缩小范围
价格
本网站仅用于提供价格信息,具体采购需联系当地办公室
结果 1-15 总共 43 个产品.
排序   看
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4)
数量
单价
1-99100-249250-499500-999>999
US$283.25US$271.90US$254.95US$243.60RFQ
Limited stock
目前库存有限。即将补货。请联系我们获得详细情况。
In Development
数量
单价
US$263.20US$252.70US$236.90US$226.40RFQ
coming soon
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4), 2GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
数量
单价
US$241.10US$231.45US$216.95US$207.35RFQ
Limited stock
In Development
数量
单价
US$220.70US$211.95US$198.65US$189.85RFQ
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
数量
单价
US$236.60US$231.90US$217.70US$203.50RFQ
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit), 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit) with ECC, 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8DualXPlus, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
coming soon
Apalis T30 2GB | V1.1A
Product Change Notification
数量
单价
US$175.55US$168.55US$158.00US$151.00RFQ
Limited stock
Apalis T30 2GB | V1.1B
Volume Product
数量
单价
Limited stock
Apalis T30 1GB | V1.1A
数量
单价
US$163.60US$157.05US$147.25US$140.70RFQ
in stock
Apalis T30 1GB | V1.1B
Volume Product
数量
单价
Limited stock
Volume Product
数量
单价
US$179.95US$172.80US$162.00US$154.80RFQ
Limited stock
Volume Product
数量
单价
US$153.70US$147.55US$138.30US$132.20RFQ
in stock
Volume Product
数量
单价
US$125.65US$120.60US$113.05US$108.05RFQ
in stock
