NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 1GB DDR3L (16 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
