Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB-C (DualRole), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 98x GPIOs
Physical: 7-24V DC ±10% Supply Voltage, Size: 250mm x 200mm
Physical: 5-24V DC ±10% or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
Connectivity: USB 3.0: 1x USB-A (Host), USB 2.0: 1x USB-A (Host), 1x USB-C (DualRole), 1x Gigabit Ethernet, 2x I2C, 1x SPI, 2x PWM, 4x ADC, 1x Via transceiver/ 1x On extension connector CAN, 31x GPIOs
Multimedia:
Physical: 8-25V DC ±10% Supply Voltage, Size: 120mm x 120mm
