单价US$283.20US$271.90US$254.90US$243.60
库存紧张
单价US$263.15US$252.65US$236.85US$226.35
库存紧张
单价US$241.05US$231.40US$216.95US$207.30
库存紧张
单价US$220.75US$211.90US$198.65US$189.85
即将上线
单价US$249.90US$239.90US$224.90US$214.90
库存紧张
单价US$190.80US$183.20US$171.75US$164.10
即将上线
单价US$185.40US$177.95US$166.85US$159.45
即将上线
单价US$130.45US$125.25US$117.40US$112.20
即将上线
单价US$185.50US$178.10US$166.95US$159.55
库存紧张
单价US$167.90US$161.15US$151.10US$144.40
现货
单价US$153.70US$147.55US$138.35US$132.20
现货
单价US$125.65US$120.60US$113.10US$108.05
现货
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB Flash, Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
单价US$131.40US$126.15US$118.30US$113.05
库存紧张
