Windows CE 功能汇总
Windows CE 5.0 / 6.0 |
Windows Embedded Compact 7.0 | Windows Embedded Compact 2013 | |
Overview | |||
Toradex Products with included Run Time License |
Windows CE 5.0 / 6.0 Core Colibri PXA, Colibri Txx, Colibri VFxx, Colibri iMX6, Apalis T30, Apalis iMX6 |
Windows Embedded Compact 7.0 NR Colibri Txx, Colibri VFxx, Colibri iMX6, Colibri iMX7, Apalis T30, Apalis iMX6 |
Windows Embedded Compact 2013 Entry Colibri Txx, Colibri VFxx, Colibri iMX6, Colibri iMX7, Apalis T30, Apalis iMX6 |
Toradex Products with Optimised BSP |
Colibri PXA, |
Colibri Txx, Colibri VFxx, Colibri iMX6, Apalis T30, Apalis iMX6 | Colibri T30, Colibri VFxx, Colibri iMX6, Apalis T30, Apalis iMX6 |
Additional images from Toradex | |||
Application Development Environment | Visual Studio 2008 | Visual Studio 2008 | Visual Studio 2013 |
Minimum Availability of OS Support | 2022 | 2026 | 2028 |
OS Feature Set (not all modules support all OS features, check individual module datasheet for details) |
Preemptive Multitasking | |||
Support for Multi-Core | - | ||
Protected Application Memory Space | |||
Snapshot Boot | - | - | |
Real Time Capabilities | |||
Interrupt Latency <7 uS | |||
.NET Compact Framework | Version 2.0 and 3.5 | Version 2.0 and 3.5 | Version 3.9 |
Component Services: COM, DCOM | |||
XML | |||
Servers (DHCP, File, Telnet, FTP, HTTP, Time) | |||
RAM Based Registry (alternative: hive based) | |||
FAT / TFAT (Transaction Safe FAT) | |||
exFAT | (1) | ||
Power Management | |||
DirectDraw Graphics Including Alpha Blending | |||
Touch | |||
Touch Gestures | - | ||
Audio with Codecs | |||
DirectShow and Video Codecs | |||
3D Acceleration | |||
OpenGL ES V2.0 | - | ||
USB: Storage Device, HID, RNDIS, ActiveSync | |||
UART, LAN, TCP/IP | |||
IrDA | - | - | |
WLAN, Bluetooth | |||
SDIO | |||
SDSC, SDHC, SDXC Support (2) | |||
Authentication Services: NTLM, SSL/TLS, Kerberos | |||
Support for International Fonts and Languages | |||
Toradex Software(3) | |||
Colibri Tweak/Display Tool | |||
GPIO Configurator | |||
Bootloader and OS Update Tool | |||
Application launcher | |||
Easy Production Programming | |||
Toradex Libraries (Cloud, GPIO, Interrupt, PWM, ADC, I2C, SPI, CAN, and more) |
Example Third Party Software (4) | |||
Software PLC | CODESYS (3S), ProConOS (KW) | ||
Java VM | Creme (NSIcom) | ||
Infotainment Framework | EB GUIDE (Elekrobit) | ||
Java Programming System | Eve (Ewesoft.com) | ||
Application Framework | Qt | ||
Lab Automation Framework | LabVIEW (National Instruments) | ||
HMI Framework | UI Composer (NVIDIA) | ||
HTML5 Web Browser | Webkit Browser (Zetakey) | ||
Silverlight for Windows Embedded | XAML In The Hand (In The Hand) |
Notes:
(1) Not WinCE 5.0
(2) The default file system on SDXC cards is exFAT, which is not supported by Windows CE5. Using SDXC cards is still possible with Windows CE5 when using other file system e.g. FAT32. Windows CE6 and Windows Embedded Compact 7 & 2013 support exFAT
(3) For complete list of tools, please refer WEC Tools & Utilities
(4) For more details on supported third party software, please refer to our Partner page
