您已经选择
搜索
缩小范围
询价
结果 1-15 总共 58 个产品.
排序
Apalis TK1 2GB | V1.1A
Sample Product
NVIDIA® Tegra™ K1
NXP® Kinetis™ K20 Companion MCU, ARM Cortex™-A15
Cortex™-M4 (Companion MCU), Up to 2.1 GHz (A15)
100 MHz (M4), Quad Core (A15)
Heteregenous (M4 Companion MCU), 2GB DDR3L (64 Bit), 16GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -25° to +85° C Temp. Range, Availability until 2025
数量
单价
1-99100-249250-499500-999≥1000
US$236.60US$231.90US$217.70US$203.50RFQ
in stock
Apalis iMX8 | V1.0A
In Development
NXP® i.MX 8QuadMax, ARM Cortex™-A72, Cortex™-A53, Cortex™-M4, 1.6GHz (A72), 1.2GHz (A53), 266MHz (M4), Dual Core (A72), Quad Core (A53), Dual Core (M4), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C
-40° to +85° C Temp. Range, Availability until 2030
coming soon
Apalis T30 2GB | V1.1A
Volume Product
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 2GB DDR3L (32 Bit), 8GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
数量
单价
US$175.55US$168.55US$158.00US$151.00RFQ
in stock
Apalis T30 1GB | V1.1A
Product Change Notification
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 1GB DDR3L (32 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2025
数量
单价
US$163.60US$157.05US$147.25US$140.70RFQ
in stock
NVIDIA® Tegra™ 3, ARM Cortex™-A9, Up to 1.4 GHz, Quad Core, 1GB DDR3L (32 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2025
数量
单价
US$179.95US$172.80US$162.00US$154.80RFQ
in stock
Sample Product
NXP®/Freescale i.MX 6Quad, ARM Cortex™-A9, 800 MHz, Quad Core, 2GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
单价
US$153.70US$147.55US$138.30US$132.20RFQ
in stock
Volume Product
NXP®/Freescale i.MX 6Quad, ARM Cortex™-A9, 1.0 GHz, Quad Core, 1GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
单价
US$125.65US$120.60US$113.05US$108.05RFQ
in stock
Sample Product
NXP®/Freescale i.MX 6Dual, ARM Cortex™-A9, 800 MHz, Dual Core, 1GB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, -40° to +85° C Temp. Range, Availability until 2028
数量
单价
US$131.65US$126.35US$118.45US$113.20RFQ
low stock
目前库存有限。即将补货。请联系我们获得详细情况。
NXP®/Freescale i.MX 6Dual, ARM Cortex™-A9, 1.0 GHz, Dual Core, 512MB DDR3 (64 Bit), 4GB eMMC (8 Bit), 10/100/1000 Mbit IEEE1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2028
数量
单价
US$112.05US$107.60US$100.85US$96.40RFQ
in stock
Volume Product
Small form-factor Apalis ARM Computer Module family Carrier Board
Connectivity: USB 3.0: 2x Host, USB: 1x Host (High Speed)
1x OTG (High Speed), 10/100/1000 Mbit Ethernet, 2x I2C, 1x SPI, 4x PWM, 4x ADC, 2x CAN, 2x LEDs, up to 40 GPIOs
Multimedia: Audio out: 1x (Stereo), Audio in: 1x (Stereo), 1x S/PDIF In / Out, 1x Camera Parallel Interface, 4/5-wire Resistive Touch
Physical: 7-27V DC Supply Voltage, 5V 5A
3.3V 5A On-Board Power Supplies, Size: 125 x 90 mm
数量
单价
US$99.70US$94.10US$91.85US$89.60RFQ
in stock
Evaluation Product
Connectivity: USB 3.0: 1x Host, 1x OTG, USB: 4x Host (High Speed), 10/100/1000 Mbit Ethernet, 3x I2C, 2x SPI, 4x PWM, 4x ADC, 2x CAN, 8x Switches, 8x LEDs, up to 135 GPIOs
3.3V 5A On-Board Power Supplies, Size: 250 x 250 mm
数量
单价
1
US$229.00
in stock
Volume Product
Heatsink for Apalis iMX6Q IT and Apalis iMX6D IT modules
Compatible with Apalis iMX6Q IT and Apalis iMX6D IT, Contains the TIM (Thermal Interface Material) and 4 screws, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additonal threaded holes available for attaching fan to the carrier board.
数量
单价
US$12.35US$11.20US$10.10US$9.00RFQ
in stock
Volume Product
Heatsink for Apalis T30 module
Compatible with Apalis T30, Contains the TIM (Thermal Interface Material) and 4 screws, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additonal threaded holes available for attaching fan to the carrier board.
数量
单价
in stock
Volume Product
Heatsink for Apalis TK1, iMX6Q and iMX6D modules
Compatible with Apalis iMX6Q, Apalis iMX6D and Apalis TK1, Contains the TIM (Thermal Interface Material) and 4 screws, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additonal threaded holes available for attaching fan to the carrier board.
数量
单价
in stock
Evaluation Product
Mezzanine board for Apalis T30 module
x16 (x4 mode) PCI Express slot, Push button for entering Apalis T30 recovery mode, CSI and DSI interfaces on one connector, Push button for Apalis T30 reset.
数量
单价
1
US$35.85
in stock
