初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:10製品中1-10
並べ替え
  表示件数
V1.1A
Apalis iMX8QM
PN: 00671100
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 8GB LPDDR4 (64 bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $375.00
    $360.00
    $337.50
    $322.50
V1.1E
Apalis iMX8QM
PN: 00371104
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $324.85
    $311.85
    $292.35
    $279.35
V1.1D
Apalis iMX8QM
PN: 00481103
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 2GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -25° to 85° C Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $268.75
    $258.00
    $241.90
    $231.15
V1.1A
Verdin iMX8M Plus - Front
PN: 00581100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $173.75
    $166.80
    $156.40
    $149.45
V1.1E
PN: 00551104
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $133.60
    $128.30
    $120.25
    $114.90
V1.1A
Verdin iMX8M Mini DualLite 1GB  Wi-Fi / Bluetooth IT
PN: 00601100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $120.65
    $115.80
    $108.60
    $103.75
V1.0D
Colibri iMX8X Front
PN: 00381003
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2035+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $186.25
    $178.80
    $167.65
    $160.20
V1.0D
Colibri iMX8X Front
PN: 00511003
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $149.35
    $143.40
    $134.45
    $128.45
V1.1A
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT
PN: 00401100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $76.15
    $73.10
    $68.55
    $65.50
V1.1A
PN: 00451100
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $68.10
    $65.40
    $61.30
    $58.60
Have a Question?
