Apalis T30
The Apalis T30 is a small form-factor Computer on Module based on the NVIDIA© Tegra 3 SoC. The Cortex A9 quad core CPU offers an operational frequency up to 1.4 GHz. The module offers high performance and advanced graphic capabilities at optimal power consumption. The module also exposes wide range of high-speed and advanced interfaces such as Gbit Ethernet, PCIe, SATA and many more.
Highlights
Powered by NVIDIA: Tegra 3 Quad Core Processor
The integrated NVIDIA Graphics enables visually rich, smooth and fast user interfaces.
Supreme Graphics Performance for Demanding Applications
The Apalis T30 module targets a wide range of applications, including: Digital Signage, Medical Devices, Navigation, HMIs, Avionics, Entertainment System, Thin Clients, Robotics, Gaming and many more.
It offers a wide range of interfaces from simple GPIOs, industry standard I2C, SPI, UART, to advanced interfaces such as Gbit Ethernet, PCIe, SATA, etc. It also supports many multimedia interfaces including LVDS, HDMI, Digital Audio, etc.
Robust and Pin-compatible Apalis Family
Based on the valuable input of our customers and our engineers‘ in-depth industry expertise, Apalis brings to market many new technologies. Direct Breakout™ considerably simplifies routing of high speed signals on the baseboard. MXM SnapLock™ provides a unique connector mechanism for module fixation. Apalis also comes with support for ready-made passive cooling solutions for the most demanding applications.
Latest Information on Apalis T30
You can find the latest information on Apalis T30 at the Toradex Developer Center
Toradex Developer CenterOperating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NVIDIA Tegra 3 processor based Colibri and Apalis T30 SoMs. This allows system designers to focus the application only instead of focusing on the OS and low-level device drivers. Other OS such as Android are supported by our partners.
Embedded Linux
For general information about the advantages and features, check our Embedded Linux page.
Windows Embedded Compact 7 and 2013 are supported on both Colibri and Apalis T30. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio. Microsoft is providing support and updates for Embedded Compact 2013 until year 2028.
The price of the Colibri and Apalis T30 modules includes a runtime license for Windows Embedded Compact 2013 Entry (C13Entry) which is backward compatible to earlier Windows CE versions.
Carrier Boards
Accessories
- Compatible with Apalis T30
- CSI and DSI interfaces on one connector
- Push button for Apalis T30 reset
- No special drivers required
- Atmel touch driver
Buy Now
Unit Price$185.50$178.10$166.95$159.55
Limited stock
Limited stock
Unit Price$167.90$161.15$151.10$144.40
In stock
Limited stock
Unit Price$188.90$181.35$170.00$162.45
Limited stock
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Quantity>0
Unit Price$245.00
In stock
Heatsink for Apalis T30 module
Compatible with Apalis T30, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additional threaded holes available for attaching fan to the carrier board.
Unit Price$11.20$10.75$10.10$9.65
In stock
Heatsink Fan is compatible with all Apalis Heatsink types and plug-and-play with Apalis Evaluation Board and Ixora Carrier board.
The fan is intended for development and evaluation purposes only.
Compatible with Apalis Evaluation Board and Ixora Carrier Board.
Quantity>0
Unit Price$15.00
In stock
Mezzanine board for Apalis T30 module
CSI and DSI interfaces on one connector, Push button for Apalis T30 reset.
Quantity>0
Unit Price$43.70
In stock
Touch: 4-Wire Resistive Touch, 40 pin FFC cable (250mm) to connect it with a Carrier Board, No special drivers required, -20° to +70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price$89.00
In stock
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board, Atmel touch driver, -20° to +70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price$99.70
In stock
Quantity1-99100-249250-499>499
Unit Price$21.30$19.00$17.90
In stock
Parallel data output format: 8-Bit Parallel ITU-R BT.656 with external HSync and VSync, No external power supply required, Compatible with Colibri Evaluation Board and Apalis Evaluation Board, -10°C to +60°C Temp, Range. Size: 60 x 50 x 9.4 mm.
Quantity>0
Unit Price$43.70
In stock
Power Adapter: 12VDC 30W with international plugs, Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board.
Quantity>0
Unit Price$32.50
Limited stock
