Apalis Arm Family
Apalis is a scalable System on Module (SoM) / Computer on Module (CoM) family that aims to provide high performance in a compact form factor. Apalis enables the development of advanced and robust products within a short time and with low risks. Apalis modules scale to the highest performance in the Toradex product range, and they provide the most interfaces of any product line on the 314-pin MXM connectors. Apalis modules are suited to a larger number of applications in such fields as healthcare, industrial automation, robotics, smart cities and many more. Apalis modules are supported by Toradex software offerings and the company’s rich ecosystem of other products and services.
Highlights
The Apalis Computer on Module Family
A72
A72
A53
A53
A53
A53
M4
3D GPU OpenVX/OpenCL
4GB RAM
16GB FLASH
A15
A15
A15
A15
M4
3D GPU CUDA
2GB RAM
16GB FLASH
A35
A35
A35
A35
M4
3D GPU OpenCL
2GB RAM
8GB FLASH
ECC
A9
A9
A9
A9
3D GPU
2GB RAM
8GB FLASH
A9
A9
A9
A9
3D GPU
2GB RAM
4GB FLASH
Software
Apalis Computer on Modules - Comparison Table
General: Some interfaces are available on pins that are not entirely compatible within the Apalis Computer on Module family. There are restrictions to using different interfaces simultaneously, please check the respective datasheet for exact details.
