Apalis iMX6
The Apalis iMX6 is the second product in the new Apalis module family by Toradex. Complementing the existing Colibri module family, Apalis comes with a wide range of new and exciting features, ensuring customers can develop the most advanced, robust products with minimum overhead and risk. Apalis supports a huge variety of industry standard interfaces, while at the same time providing advanced multimedia and high speed connectivity making it suitable for an almost unlimited number of applications.
Highlights
Powered by NXP® i.MX 6: i.MX 6Quad and i.MX 6Dual Processors
The Apalis iMX6 is a small form-factor Computer on Module/System on Module that comes in both quad core and dual core versions based on NXP (formerly Freescale) i.MX 6Q and NXP i.MX 6D SoCs respectively. The Cortex A9 quad core and dual core CPU peaks at 1 GHz for commercial temperature variant, while the industrial temperature variant has a peak frequency of 800 MHz.
Extensive Industrial and High-speed interfaces
The NXP (formerly Freescale) i.MX 6 based Apalis iMX6 System on Module targets a wide range of industrial applications, including: Automotive & Infotainment, Navigation, Industrial Automation, HMIs, Avionics, Robotics, and much more.
The module exposes wide range of industrial interfaces including CAN, UART, I2C, USB, PCIe, SATA, and many more.
Apalis iMX6 is a reference platform for Qt for Device Creation. For more details, check here
Robust and Pin-compatible Apalis Family
Based on the valuable input of our customers and our engineers‘ in-depth industry expertise, Apalis brings to market many new technologies. Direct Breakout™ considerably simplifies routing of high speed signals on the baseboard. MXM SnapLock™ provides a unique connector mechanism for module fixation. Apalis also comes with support for ready-made passive cooling solutions for the most demanding applications.
Latest Information on Apalis iMX6
Operating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NXP i.MX 6 processor based Colibri and Apalis iMX6 SoMs. This allows system designers to focus the application instead of focusing on the OS and low-level device drivers. Other OS such as QNX and Android are supported by our partners.
Torizon
Torizon is a new Linux-based software platform that simplifies the process of developing and maintaining embedded software. It allows you to configure the system for your use case quickly and easily, so you can focus on application development instead of Linux builds.
For general information about the advantages and features, check our Torizon page.
Embedded Linux
For general information about the advantages and features, check our Embedded Linux page.
Windows Embedded Compact 7 and 2013 are supported on both Colibri and Apalis iMX6. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio. Microsoft is providing support and updates for Embedded Compact 2013 until year 2028.
The price of the Colibri and Apalis iMX6 modules includes a runtime license for Windows Embedded Compact 2013 Entry (C13Entry) which is backward compatible to earlier Windows CE versions.
QNX
QNX on NXP i.MX 6-based modules is supported by our service partner Triadem.
Triadem will be soon offering a QNX demo image for Colbiri iMX6.
Carrier Boards
Accessories
- Compatible with Apalis iMX6Q IT and Apalis iMX6D IT
- 1x Tactile switch to enter Apalis iMX6 module recovery mode
- 1x Tactile switch to reset Apalis iMX6 module
- No special drivers required
- Atmel touch driver
Buy Now
In stock
In stock
Limited stock
Limited stock
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Quantity>0
Unit Price$245.00
In stock
Heatsink for Apalis iMX6Q IT and Apalis iMX6D IT modules
Compatible with Apalis iMX6Q IT and Apalis iMX6D IT, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additional threaded holes available for attaching fan to the carrier board, -40°C to +200°C Temp.
Unit Price$11.20$10.75$10.10$9.65
In stock
Heatsink for Apalis TK1, iMX6Q and iMX6D modules
Compatible with Apalis iMX6Q, Apalis iMX6D and Apalis TK1, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additional threaded holes available for attaching fan to the carrier board, -40°C to +200°C Temp.
Limited stock
Mezzanine board for Apalis iMX6 module
1x Tactile switch to enter Apalis iMX6 module recovery mode, 1x Tactile switch to reset Apalis iMX6 module, -40° to +85° C Temp, Range. Size: 100 x 60 mm.
Quantity>0
Unit Price$43.70
In stock
Touch: 4-Wire Resistive Touch, 40 pin FFC cable (250mm) to connect it with a Carrier Board, No special drivers required, -20° to +70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price$89.00
In stock
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board, Atmel touch driver, -20° to +70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price$99.70
In stock
Quantity1-99100-249250-499>499
Unit Price$21.30$19.00$17.90
In stock
Parallel data output format: 8-Bit Parallel ITU-R BT.656 with external HSync and VSync, No external power supply required, Compatible with Colibri Evaluation Board and Apalis Evaluation Board, -10°C to +60°C Temp, Range. Size: 60 x 50 x 9.4 mm.
Quantity>0
Unit Price$43.70
In stock
Power Adapter: 12VDC 30W with international plugs, Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board.
Quantity>0
Unit Price$32.50
Coming soon
