Colibri T20
The Colibri T20 is a SODIMM sized computer module based on the NVIDIA© Tegra 2 embedded system-on-a-chip. The Cortex A9 dual core CPU peaks at 1 GHz. The module delivers high CPU and graphic performance with minimum power consumption. The module also meets stringent industrial temperature range.
The Colibri T20 product group is end-of-life (EOL). For further details please check the revision history of the product and the related PCN. Customers using end-of-life (EOL) Tegra products are advised to use our migration guide to seamlessly migrate to recommended hardware and software solutions for their products.
For a direct replacement, Toradex recommends the Colibri iMX6, Colibri iMX8 product group or a transition to the Verdin product family.
Highlights
Powered by NVIDIA: Tegra 2 Dual Core Processor
The integrated NVIDIA Graphics enables visually rich, smooth and fast user interfaces.
Supreme Graphics Performance for Demanding Applications
The module targets a wide range of applications, including: Digital Signage, Medical Devices, Navigation, Industrial Automation, HMIs, Avionics, Entertainment System, POS, Data Acquisition, Thin Clients, Robotics, Gaming and much more
It offers a wide range of interfaces from simple GPIOs, industry standard I2C and SPI buses through to high speed USB 2.0 interfaces and a high speed memory bus. The HDMI interface makes it very easy to connect large, full HD resolution displays.
Easy Performance Upgrade
Existing customers will benefit from an extremely easy migration path from the current Colibri PXAxxx module range to the Colibri T20 – all Colibri modules are electrically pin compatible. New customers will also appreciate the ability to select the Colibri module most suitable for their application to achieve the optimum price/performance balance without the need to support different carrier board designs.
Latest Information on Colibri T20
You can find the latest information on Colibri T20 at the Toradex Developer Center
Toradex Developer CenterOperating Systems
Toradex offers free support and maintenance for Windows Embedded Compact and Embedded Linux on the NVIDIA Tegra 2 processor based Colibri T20 SoMs. This allows system designers to focus the application only, instead of focusing also on the OS and low-level device drivers. Other OS such as Android will be supported by our partners.
Embedded Linux
For general information about the advantages and features, check our Embedded Linux page.
Windows Embedded Compact 7 and 2013 are supported on Colibri T20. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
The price of the Colibri T20 modules includes a runtime license for Windows Embedded Compact 2013 Entry (C13Entry) which is backward compatible to earlier Windows CE versions.
Carrier Boards
- No special drivers required
- Atmel touch driver
