Colibri iMX6ULL
Colibri iMX6ULL is the first Toradex's Computer Module offering on-board Wi-Fi and Bluetooth. The Colibri iMX6ULL is a SODIMM-sized SoM based on NXP i.MX 6ULL application processor, featuring a power-efficient Arm® Cortex-A7 core.
Highlights
Equipped with NXP i.MX 6ULL SoCs, the Arm Cortex-A7 single core is clocked at 528 MHz, 800 MHz or 900 MHz depending on the configuration of the SoM.
The NXP i.MX 6ULL SoC is a power-efficient processor which, in addition to being a single-core, allows for a power dissipation of the Toradex SoM in the order of 0.4W to 1.2W, depending on the system load.
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Carrier boards designed for the Colibri iMX6ULL are not just compatible between the four Colibri iMX6ULL modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 7, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Colibri iMX6ULL offers a low-cost and power-efficient platform to build a wide range of IoT and embedded devices. It is suitable for headless applications, or static GUIs and light multimedia as low resolution video.
Operating Systems
Toradex offers free support and maintenance for Embedded Linux on the NXP i.MX 6ULL processor based Colibri iMX6ULL SoM. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers.
Ecosystem
Toradex Easy Installer
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX6ULL and choose an OS!
Colibri iMX6ULL does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Qt
TotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX6ULL is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
Get started with CODESYS on Toradex SoMsMatrikon OPC UA
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX6ULL perfectly.
Watch our webinar with BE.servicesCarrier Boards
Accessories
- No special drivers required
- Atmel touch driver
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
Roadmap
Min. Product Commitment
As per NXP Roadmap
- 2020
- 2021
- 2022
- 2023
- 2024
- 2025
- 2026
- 2027
- 2028
- 2029
- 2030
- 2031
- 2032
Hardware Roadmap
- Q1'22
- Q2'22
- Q3'22
- Q4'22
- Q1'23
- In Development
- Early access product
- Sample Product
- Volume Product Candidate
- Volume Product
Embedded Linux Support Status
Implemented Features and Software Roadmap
This list provides an overview about the most important implemented and planned software features for this product. The detailled feature list and roadmaps can be found on the Developer Website's Linux BSP Release Details and the Developer Website's Linux BSP Release Roadmap.
Ready to use
- Parallel RGB display
- USB Host
- SDIO / SD card
- Analog input
- PWM
- I2C
- DVFS
- RTC
- On-board Bluetooth
- Ethernet
- USB Client
- Resistive Touch 4-wire
- UART
- CAN
- SPI
- Watchdog
- Suspend / Resume
- On-board Wi-Fi
- RS485
Buy Now
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 1GB DDR3L (16 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
Unit Price$73.00$70.10$65.70$62.80
In stock
Unit Price$78.15$75.05$70.35$67.20
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
Unit Price$67.50$64.80$60.75$58.05
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 800 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2032
Unit Price$58.75$56.40$52.85$50.50
Limited stock
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 528 MHz, 256MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
Unit Price$44.95$43.15$40.45$38.65
Limited stock
Quantity>0
Unit Price$235.90
In stock
Unit Price$66.40$63.75$59.75$57.10
Limited stock
Unit Price$31.00$29.75$27.90$26.65
In stock
Unit Price$36.90$35.40$33.20$31.75
Limited stock
Quantity>0
Unit Price$69.00
In stock
Fasteners for Colibri modules
Quantity>0
Unit Price$35.00
In stock
Touch: 4-Wire Resistive Touch. 40 pin FFC cable (250mm) to connect it with a Carrier Board. No special drivers required. -20° to +70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price$99.00
In stock
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board. Atmel touch driver. -20° to +70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price$115.00
In stock
Plug and Play (Windows Compact Embedded 6/7 compatible). BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes. WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes. Can be setup as a ad-hoc network via peer to peer communications. -10°C to +60°C Temp, Range. Size: 17 x 15 x 8 mm.
Quantity1-99100-249250-499>499
Unit Price$23.50$20.00$18.85
In stock
Power Adapter: 12VDC 30W with international plugs. Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board, Verdin Development Board, Dahlia Carrier Board.
Quantity>0
Unit Price$35.00
Limited stock
Cable length: 100mm. Frequency bands: 2.4 GHz and 5 GHz (dual-band). Manufacturer: Unictron. Reference: AA222 (H2B1PD1A1C385L), Range. Size: 40.0 x 6.0 x 0.5 mm.
Unit Price$4.60$3.40$2.85$2.50
Limited stock
Frequency bands: 2.4 GHz and 5 GHz (dual-band). Manufacturer: Chang Hong. Reference: DA-2458-02, Range. Size: 106.0 x 10.0 (max. diameter) mm.
Unit Price$5.90$4.45$3.75$3.25
In stock
Unit Price$4.75$3.55$2.95$2.60
In stock
Cable length: 200mm.
Unit Price$7.10$5.35$4.45$3.90
In stock
Cable length: 200mm. Suitable for outdoor-usage (IP67).
Unit Price$10.65$8.00$6.65$5.80
In stock
