Colibri iMX7
The Colibri iMX7S and Colibri iMX7D are SODIMM-sized System on Modules (SoMs) based on the NXP i.MX 7Solo and i.MX 7Dual SoCs respectively. Arm Cortex-A7 cores are highly optimized for energy efficiency while delivering high performance. Advanced security features make the Colibri iMX7 a great choice for connected devices. Typical applications include power-sensitive edge computing devices, IoT gateways, medical devices, industrial automation and many more. The NXP i.MX 7 uses an asymmetric, heterogeneous multicore processing system with a Cortex-M4 core that runs at up to 200MHz.
Highlights
Equipped with NXP i.MX 7S and NXP i.MX 7D SoCs, the Arm Cortex-A7 cores are clocked at 1GHz, making it an ideal choice for powerful yet efficient applications.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex M4 for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode.
The NXP i.MX 7 SoC is a power-efficient processor. In addition, the Heterogeneous Multicore Processing (HMP) provided by the Cortex-M4 allows for a low-power mode where the Cortex-A is shutdown to greatly reduce the power consumption.
The SoM is available with a tightly integrated Torizon Platform accelerating the development and maintaining your products. Some key features include highly secure and reliable remote updates, fleet monitoring and remote access.
Carrier boards designed for the Colibri iMX7 are not just compatible between the three Colibri iMX7 modules—in fact, they are compatible with the complete Colibri family, including the NXP i.MX 8X, i.MX 6 and NVIDIA Tegra-based modules. This gives you unmatched flexibility and easy upgradability. Currently, there are eight different modules with over 20 variations available. To make carrier board design as easy as possible, we provide the Toradex Pinout Designer Tool.
Operating Systems
Toradex offers free support and maintenance for Embedded Linux and Windows CE on the Colibri iMX7 SoMs. This allows system designers to focus on the application instead of focusing on the OS and low-level device drivers. Other OS such as QNX and Android are supported by our partners.
Toradex enables NXP’s FreeRTOS on Colibri iMX7. FreeRTOS is a real-time OS that runs on the Cortex-M4 core in parallel to the main OS.
Android on Colibri iMX7 is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds.
Ecosystem
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Colibri iMX7 and choose an OS!
Colibri iMX7 does not have a GPU. Nevertheless, choosing a GUI framework that supports optimized graphics on the CPU is a great choice for a modern UI with moderate level of animations. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank Storyboard
TotalCross
Get started with TotalcrossIndustrial Automation
CODESYS PLC IEC 61131-3
The Colibri iMX7 is a good fit for industrial automation tasks. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Colibri iMX7 perfectly.
Watch our webinar with BE.servicesCarrier Boards
- No special drivers required
- Atmel touch driver
Roadmap
Hardware Roadmap
For details about the Toradex phase-over policy please refer to the PCN Policy Page.
- 2022
- 2023
- 2024
- 2025
- 2026
- 2027
- Volume Product
Software Support Status
Windows Embedded Compact
Latest Version
BSP
1.2b4
WEC 7 Microsoft Patch Level
September 2018
WEC 2013 Microsoft Patch Level
October 2018
Stable Version
BSP
1.1
December 2017
April 2018
Implemented Features and Software Roadmap
This list provides an overview about the most important implemented and planned software features for this product on Windows CE. The detailed feature list and roadmaps can be found on the BSP Release Details.
Ready to use
- Parallel RGB display
- USB Host (not available on Colibri iMX7S)
- SDIO / SD card
- Analog Audio Out
- Analog input
- RS485
- CAN
- SPI
- Watchdog
- RTC
- Ethernet
- USB Client
- Analog Audio In
- Resistive Touch 4-wire
- UART
- PWM
- I2C
- Multimedia playback (software)
Buy Now
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 1GB DDR3 (32 Bit), 4GB eMMC, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to 85° C Temp. Range, Availability until 2035
Unit Price€89.90€86.30€80.90€77.30
In stock
NXP® i.MX 7Dual, 2x Arm Cortex™-A7, 1.0 GHz (A7), 200 MHz (M4), 512MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RGMII/RMII/MII) Ethernet, -20° to 85° C Temp. Range, Availability until 2035
Unit Price€83.10€79.80€74.80€71.50
In stock
NXP® i.MX 7Solo, 1x Arm Cortex™-A7, 800 MHz (A7), 200 MHz (M4), 256MB DDR3 (32 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 Ethernet, -20° to 85° C Temp. Range, Availability until 2035
Unit Price€77.25€74.15€69.55€66.45
In stock
Quantity>0
Unit Price€209.50
In stock
Unit Price€70.00€67.20€63.00€60.20
Limited stock
Unit Price€31.00€29.75€27.90€26.65
In stock
Unit Price€37.50€36.00€33.75€32.25
In stock
Quantity>0
Unit Price€61.80
In stock
Fasteners for Colibri modules
Quantity>0
Unit Price€23.80
In stock
Touch: 4-Wire Resistive Touch. 40 pin FFC cable (250mm) to connect it with a Carrier Board. No special drivers required. -20° to +70° C Temp, Range. Size: 164.9 x 100.0 x 13.0 mm.
Quantity>0
Unit Price€93.80
In stock
40 pin and 10 pin FFC cable (250mm) to connect it with a Carrier Board. Atmel touch driver. -20° to +70° C Temp, Range. Size: 173 x 112 x 13 mm.
Quantity>0
Unit Price€113.80
In stock
Plug and Play (Windows Compact Embedded 6/7 compatible). BPSK, QPSK, 16 QAM, 64 QAM, DBPSK, DQPSK, and CCK modulation schemes. WEP, TKIP, and AES, WPA, WPA2 hardware encryption Schemes. Can be setup as a ad-hoc network via peer to peer communications. -10°C to +60°C Temp, Range. Size: 17 x 15 x 8 mm.
Quantity1-99100-249250-499>499
Unit Price€23.80€19.80€18.50
In stock
Parallel data output format: 8-Bit Parallel ITU-R BT.656 with external HSync and VSync. No external power supply required. Compatible with Colibri Evaluation Board and Apalis Evaluation Board. -10°C to +60°C Temp, Range. Size: 60 x 50 x 9.4 mm.
Quantity>0
Unit Price€47.50
In stock
Power Adapter: 12VDC 30W with international plugs. Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board, Verdin Development Board, Dahlia Carrier Board.
Quantity>0
Unit Price€47.50
In stock
