見積依頼
検索結果:94製品中1-20
並べ替え
  表示件数
V1.1A
Apalis iMX8QM
PN: 00671100
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 8GB LPDDR4 (64 bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $375.00
    $360.00
    $337.50
    $322.50
使用目的: For End Products
V1.1E
Apalis iMX8QM
PN: 00371104
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $324.85
    $311.85
    $292.35
    $279.35
V1.1D
Apalis iMX8QM
PN: 00471103
Volume Production
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $299.90
    $287.90
    $269.90
    $257.90
V1.1D
Apalis iMX8QM
PN: 00481103
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 2GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -25° to 85° C Temp. Range, Availability until 2034+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $268.75
    $258.00
    $241.90
    $231.15
V1.1D
Apalis iMX8QM
PN: 00491103
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $243.45
    $233.75
    $219.15
    $209.40
V1.1D
Apalis iMX6 Quad 2GB IT
PN: 00281103
Volume Production
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 800 MHz, 2GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to 85° C Temp. Range, Availability until 2036
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $206.25
    $198.00
    $185.65
    $177.40
Due to limited availability and longer lead times, please consider the Y-Version of the module if you do not need the resistive touch and ADC-functionality of the module. For additional information visit our developer page
V1.1Y
PN: 00281124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $206.25
    $198.00
    $185.65
    $177.40
Y-Version of the module does not have the resistive touch and ADC-functionality, but has higher availability and shorter lead time. For additional information visit our developer page
V1.1D
Apalis iMX6 Quad 1GB
PN: 00271103
Volume Production
NXP® i.MX 6Quad, 4x Arm Cortex™-A9, 1.0 GHz, 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2036
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $165.00
    $158.40
    $148.50
    $141.90
V1.1Y
PN: 00271124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $165.00
    $158.40
    $148.50
    $141.90
V1.1C
Apalis iMX6 Dual 1GB IT
PN: 00351102
Volume Production
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 800 MHz, 1GB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, -40° to 85° C Temp. Range, Availability until 2036
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $174.40
    $167.40
    $156.95
    $150.00
V1.1Y
PN: 00351124
Volume Production
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $174.40
    $167.40
    $156.95
    $150.00
V1.1C
Apalis iMX6 Dual 512MB
PN: 00291102
Volume Production
NXP® i.MX 6Dual, 2x Arm Cortex™-A9, 1.0 GHz, 512MB DDR3 (64 Bit), 4GB eMMC, Gigabit with IEEE 1588 Ethernet, 0° to 70° C Temp. Range, Availability until 2036
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $137.50
    $132.00
    $123.75
    $118.25
V1.1A
Verdin iMX8M Plus - Front
PN: 00701100
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 8GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2036+
  • 数量
    1-99
    >99
  • 単価
    $209.85
V1.1A
PN: 00581100
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 4GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2036+
  • 数量
    1-99
    >99
  • 単価
    $173.75
V1.1A
PN: 00631100
Sample Production
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 4GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2036+
  • 数量
    1-99
    >99
  • 単価
    $152.50
V1.1A
PN: 00641100
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2036+
  • 数量
    1-99
    >99
  • 単価
    $143.70
V1.1A
PN: 00651100
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 1GB LPDDR4 (32bit), 8GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2036+
  • 数量
    1-99
    >99
  • 単価
    $109.90
V1.1E
PN: 00551104
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with AVB Ethernet, -40° to 85° C(1) Temp. Range, Availability until 2035+
  • 数量
    1-99
    >99
  • 単価
    $133.60
V1.1D
Verdin iMX8M Mini Quad 2GB IT
PN: 00591103
Volume Production
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with AVB Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
  • 数量
    1-99
    >99
  • 単価
    $112.50
V1.1A
Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT (No CAN)
PN: 00681100
  • 数量
    1-99
    >99
  • 単価
    $121.80
Have a Question?
