You've Selected
Narrow Results
Order Now
Results: 1-2 of 2 products.
Sort By   View
NXP® i.MX 8M Mini Quad, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC (8bit), Gigabit with AVB Ethernet, -40° to +85° C(1) Temp. Range, Availability until 2030+
(1)The Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Verdin iMX8M Mini 2GB WB IT is still listed as an Industrial Temperature product.
coming soon
In Development
NXP® i.MX 8M Mini DualLite, 2x Arm Cortex™-A53, 1.8 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 8GB eMMC (8bit), Gigabit with AVB Ethernet, 0° to +70° C Temp. Range, Availability until 2030+
coming soon
