You've Selected
Narrow Results
Order Now
Results: 1-15 of 75 products.
Sort By   View
640 MHz (DSP), 4GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -40° to +85° C(2) Temp. Range, Availability until 2030+
(2) The RAM on the first Samples is not IT-grade, but will be changed in the future. Furthermore, the Wi-Fi component on the module is limited to an operating temperature range of -30° to +85°C. As this component is not deemed boot-critical, the Apalis iMX8QM 4GB WB IT is still listed as an Industrial Temperature product.
coming soon
In Development
coming soon
coming soon
In Development
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
1-99100-249250-499500-999>999
in stock
coming soon
Apalis T30 2GB | V1.1A
Product Change Notification
Quantity
Unit Price
low stock
Apalis T30 2GB | V1.1B
Volume Product
Quantity
Unit Price
low stock
Apalis T30 1GB | V1.1A
Quantity
Unit Price
in stock
Apalis T30 1GB | V1.1B
Volume Product
Quantity
Unit Price
low stock
Volume Product
Quantity
Unit Price
low stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
in stock
