PN: 00461000
coming soon
coming soon
coming soon
coming soon
low stock
low stock
in stock
low stock
low stock
in stock
in stock
low stock
low stock
low stock
low stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
low stock
