Order Now
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Connectivity: USB 2.0: 1x Host / 1x OTG, 10/100 Mbit Ethernet, 1x I2C, 1x SPI, 4x PWM, 4x ADC, up to 26 GPIOs
Unit Price$54.60$52.45$49.15$46.95
Limited stock
Limited stock
Unit Price$26.60$25.55$23.95$22.90
In stock
Unit Price$32.35$31.05$29.10$27.85
In stock
