You've Selected
Narrow Results
Order Now
Results: 1-8 of 8 products.
Sort By   View
NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4)
Quantity
Unit Price
1-99100-249250-499500-999>999
Limited stock
In Development
Quantity
Unit Price
coming soon
NXP® i.MX 8QuadPlus, 1x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72) , 1.26 GHz (A53) , 266 MHz (M4), 2GB LPDDR4 (64 Bit), 16GB eMMC (8 Bit), Gigabit with AVB (+2nd RGMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
Limited stock
In Development
Quantity
Unit Price
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
Limited stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit), 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35) , 266 MHz (M4) , 640 MHz (DSP), 2GB DDR3L (32 Bit) with ECC, 8GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
coming soon
In Development
NXP® i.MX 8DualXPlus, 2x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 1GB DDR3L (32 Bit), 4GB eMMC, Gigabit with AVB (+2nd RGMII/RMII) Ethernet, -25° to +85° C Temp. Range, Availability until 2030+
coming soon
