You've Selected
Narrow Results
Order Now
Results: 1-15 of 22 products.
Sort By   View
coming soon
In Development
coming soon
coming soon
In Development
coming soon
Apalis TK1 2GB | V1.2A
Volume Product
Quantity
Unit Price
1-99100-249250-499500-999>999
low stock
coming soon
Apalis T30 2GB | V1.1B
Volume Product
Quantity
Unit Price
low stock
Apalis T30 1GB | V1.1A
Product Change Notification
Quantity
Unit Price
in stock
Apalis T30 1GB | V1.1B
Volume Product
Quantity
Unit Price
low stock
Volume Product
Quantity
Unit Price
low stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
in stock
Volume Product
Quantity
Unit Price
low stock
Volume Product
Quantity
Unit Price
low stock
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2GHz (A35) , 266MHz (M4) , 640MHz (DSP), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to +85° C Temp. Range, Availability until 2030+
Quantity
Unit Price
>0
RFQ
low stock
