NXP® i.MX 8QuadMax, 2x Arm Cortex™-A72, 4x Arm Cortex™-A53, 1.6 GHz (A72), 1.26 GHz (A53), 266 MHz (M4), 4GB LPDDR4 (64 Bit), 32GB eMMC, Gigabit with AVB (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2034+
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB-C (DualRole), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 98x GPIOs
Physical: 7-24V DC ±10% Supply Voltage, Size: 250mm x 200mm
Physical: 5-24V DC ±10% or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
