Order Now
Results: 1-20 of 20 products.
Sort By
  View
V1.1E
PN: 00551104
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $146.85
    $141.00
    $132.20
    $126.30
V1.1C
Verdin iMX8M Mini Quad 2GB IT
PN: 00591102
NXP® i.MX 8M Mini, 4x Arm Cortex™-A53, 1.6 GHz (A53), 400 MHz (M4F), 2GB LPDDR4 (32-bit), 16GB eMMC, Gigabit with AVB Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $123.60
    $118.70
    $111.25
    $106.30
V1.1A
Verdin iMX8M Mini DualLite 1GB  Wi-Fi / Bluetooth IT
PN: 00601100
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $120.65
    $115.80
    $108.60
    $103.75
V1.1B
PN: 00571101
NXP® i.MX 8M Mini, 2x Arm Cortex™-A53, 1.8 GHz (A53), 400 MHz (M4F), 1GB LPDDR4 (32bit), 4GB eMMC, Gigabit with AVB Ethernet, 0° to 70° C Temp. Range, Availability until 2035+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $87.25
    $83.75
    $78.55
    $75.05
V1.1A
Verdin iMX8M Plus - Front
PN: 00581100
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $184.90
    $177.50
    $166.40
    $159.00
V1.1A
PN: 00631100
NXP® i.MX 8M Plus, 4x Arm Cortex™-A53, 1.6 GHz (A53), 800 MHz (M7F), 4GB LPDDR4 (32 bit), 32GB eMMC, Gigabit with TSN (+2nd RGMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2036+
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $162.25
    $155.75
    $146.05
    $139.55
V1.1D
Verdin Development Board with HDMI Adapter
PN: 99991103
Connectivity: USB 3.0: 2x USB-A (Host), USB 2.0: 1x USB-C (DualRole), 2x Gigabit Ethernet, 4x I2C, 1x SPI, 3x PWM, 4x ADC, 2x CAN, Up to 98x GPIOs
Physical: 7-24V DC ±10% Supply Voltage, Size: 250mm x 200mm
  • Quantity
    >0
  • Unit Price
    $324.00
V1.1C
Dahlia Carrier Board with HDMI Adapter
PN: 99981102
Physical: 5-27V DC or USB-C (PD and BC) Supply Voltage, Size: 120mm x 120mm
  • Quantity
    >0
  • Unit Price
    $199.90
V1.0A
Yavia
PN: 01731000
Sample Product
Connectivity: USB 3.0: 1x USB-A (Host), USB 2.0: 1x USB-A (Host), 1x USB-C (DualRole), 1x Gigabit Ethernet, 2x I2C, 1x SPI, 2x PWM, 4x ADC, 1x Via transceiver/ 1x On extension connector CAN, 31x GPIOs
Multimedia:
Physical: 8-25V DC ±10% Supply Voltage, Size: 120mm x 120mm
  • Quantity
    >0
  • Unit Price
    $229.00
V1.0A
Verdin Industrial Heatsink Type 1
PN: 23111000
Heatsink for Verdin iMX8M Mini and iMX8M Plus modules
Compatible with Verdin iMX8M Mini and Verdin iMX8M Plus. 4 screws (M2x10mm) included with each heatsink for easy mounting to Verdin Carrier Boards, Range. Size: 85.6 x 38 x 14.27 mm.
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $11.65
    $11.20
    $10.50
    $10.00
    $9.30
V1.0B
PN: 23111001
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $11.65
    $11.20
    $10.50
    $10.00
    $9.30
V1.0A
Capacitive Touch Display 10.1
PN: 12121000
Capacitive Touch Displays (LVDS) for Apalis modules
LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it with a Carrier Board. -20° to +70° C Temp, Range. Size: 248.5 x 166.1 x 15.0 mm.
  • Quantity
    >0
  • Unit Price
    $299.00
V1.1B
Carrier Board Accessory Kit
PN: 01131101
Product Change Notification
Power Adapter: 12VDC 30W with international plugs. Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board, Verdin Development Board, Dahlia Carrier Board.
  • Quantity
    >0
  • Unit Price
    $38.50
V1.0A
PN: 21541000
Cable length: 100mm. Frequency bands: 2.4 GHz and 5 GHz (dual-band). Manufacturer: Unictron. Reference: AA222 (H2B1PD1A1C385L), Range. Size: 40.0 x 6.0 x 0.5 mm.
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $4.95
    $3.75
    $3.25
    $2.85
V1.0A
PN: 21511000
Frequency bands: 2.4 GHz and 5 GHz (dual-band). Manufacturer: Chang Hong. Reference: DA-2458-02, Range. Size: 106.0 x 10.0 (max. diameter) mm.
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $5.95
    $4.50
    $3.90
    $3.45
V1.0A
Pigtail Antenna Cable MHF4 to RP-SMA 100mm and 200mm
PN: 21521000
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $4.95
    $3.75
    $3.25
    $2.85
V1.0A
PN: 21531000
Cable length: 200mm.
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $5.95
    $4.50
    $3.90
    $3.45
V1.0A
PN: 21551000
Cable length: 200mm. Suitable for outdoor-usage (IP67).
  • Quantity
    1-99
    100-249
    250-499
    500-999
    >999
  • Unit Price
    $7.95
    $5.95
    $5.15
    $4.60
V1.0A
Verdin iMX8M Plus Mezzanine
PN: 01631000
Mezzanine board for Verdin iMX8M Plus module
Key features:
  • 1x LVDS Display Connector
  • 1x MIPI CSI-2 Camera Connector
  • 1x Capacitive Touch Connector
  • -30° to +85° C Temp, Range. Size: 88mm x 48mm.
    • Quantity
      >0
    • Unit Price
      $54.90
    V1.1A
    Verdin DSI to LVDS Adapter - front
    PN: 01591100
    Range. Size: 50 x 40 mm.
    • Quantity
      >0
    • Unit Price
      $38.50
    Have a Question?
