ハイライト
Out-of-the-Box Experience with Toradex Carrier Boards
It works with the following Toradex Carrier Boards out-of-the-box:
Scope of delivery
  • 10.1” Capacitive Touch Display Panel
  • LVDS cable
  • 10 Pins 0.5mm FFC Ribbon Cable
特徴
PN: 1212
見積もり依頼
Accessory Feature 1
LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it with a Carrier Board
Resolution
1280x800, 8-bit LVDS output
Supply Voltage
Size
Temperature
3.3V
248.5 x 166.1 x 15.0 mm
-20° to +70° C
使用目的
価格
For Evaluation/Development
1 : $299.00
キャリアボード
Ixora キャリアボード
データシート
Apalis 評価ボード
データシート
Iris キャリアボード
データシート
Supported Modules
USB 3.0
USB 2.0
Ethernet
PCIe
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
Serial ATA
SDIO/SD/MMC
CAN
JTAG
Entire Apalis Family
2x Host
1x Host / 1x OTG
Gigabit
1x Mini PCIe
2x
1x
3x RS232
4x
up to 40
4x
1x mSATA
1x 4 Bit (microSD)
2x
1x Host, 1x OTG
4x Host
Gigabit
2x 1 slot / 1x Mini PCIe
3x
2x
2x RS232, 1x RS422/485
1x
4x
up to 135
4x
1x / 1x mSATA (shared)
2x 4 Bit
2x
Yes
Entire Colibri Family
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
Switches
LEDs
2x
8x
8x
LVDS
Digital Audio
S/PDIF In / Out
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Camera Parallel Interface
Camera Serial Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
1x Dual Channel
1x / 1x
1x
1x (24 Bit)
Yes
4/5-wire
1x 10 Bit
1x Quad Lane MIPI CSI-2
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
7.1 Channel HD Audio Codec (incl. analogue connectors)
1x (Out also on TOSLINK)
1x (Through DVI-I connector)
1x
1x (24 Bit)
4/5-wire
1x 8/10/12 Bit
On Mezzanine
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
Yes
Yes
1x
1x
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 6A
3.3V 8A
125 x 90 mm
0° to +70° C
-20° to +85° C(1)
7-27V DC
5V 5A
3.3V 5A
250 x 250 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
使用目的
価格
確保供給期間
For End Products
1-99 : $137.35
100-249 : $131.90
250-499 : $123.65
500-999 : $118.15
>999 : RFQ
2034+
1 : $328.90
For End Products
1-99 : $72.50
100-249 : $69.60
250-499 : $65.25
500-999 : $62.35
>999 : RFQ
2034+
見積もり依頼
1 コンピューターモジュール, 3 キャリアボード
V1.0A
PN: 12121000
Capacitive Touch Displays (LVDS) for Apalis modules
LVDS cable (250mm) and 10 pin FFC cable (250mm) to connect it with a Carrier Board. -20° to +70° C Temp, Range. Size: 248.5 x 166.1 x 15.0 mm.
  • 数量
    >0
  • 単価
    $299.00
V1.2A
Ixora キャリアボード V1.2A
PN: 01331200
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $137.35
    $131.90
    $123.65
    $118.15
V1.1C
Apalis 評価ボード V1.1C
PN: 01151102
製品変更通知
  • 数量
    >0
  • 単価
    $328.90
V2.0A
Iris キャリアボード V2.0A
PN: 01352000
ボリューム製品
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $72.50
    $69.60
    $65.25
    $62.35
Have a Question?
