初めてのお客様は、以下の内容をよくお読みください。
注文
検索結果:9製品中1-9
並べ替え
  表示件数
V1.1E
Apalis iMX8QM
PN: 00371104
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $336.15
    $322.70
    $302.55
    $289.10
V1.1C
Apalis iMX8QM
PN: 00481102
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $273.60
    $262.70
    $246.25
    $235.30
V1.1E
PN: 00551104
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $146.85
    $141.00
    $132.20
    $126.30
V1.1A
Verdin iMX8M Mini DualLite 1GB  Wi-Fi / Bluetooth IT
PN: 00601100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $120.65
    $115.80
    $108.60
    $103.75
V1.1A
Verdin iMX8M Plus - Front
PN: 00581100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $184.90
    $177.50
    $166.40
    $159.00
V1.0D
Colibri iMX8X Front
PN: 00381003
NXP® i.MX 8QuadXPlus, 4x Arm Cortex™-A35, 1.2 GHz (A35), 266 MHz (M4), 2GB LPDDR4 (32 Bit), 8GB eMMC, 10/100 Mbit with AVB (+2nd RGMII/RMII) Ethernet, -40° to 85° C Temp. Range, Availability until 2035+
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $186.25
    $178.80
    $167.65
    $160.20
V1.0D
Colibri iMX8X Front
PN: 00511003
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $149.90
    $143.90
    $134.90
    $128.90
V1.1A
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT
PN: 00401100
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $81.15
    $77.90
    $73.05
    $69.80
V1.1A
PN: 00451100
NXP® i.MX 6ULL, 1x Arm Cortex™-A7, 900 MHz, 512MB DDR3L (16 Bit), 512MB SLC NAND, 10/100 Mbit with IEEE 1588 (+2nd RMII) Ethernet, 0° to 70° C Temp. Range, Availability until 2032
  • 数量
    1-99
    100-249
    250-499
    500-999
    >999
  • 単価
    $70.00
    $67.20
    $63.00
    $60.20
Have a Question?
