NXP® i.MX 8X Computer on Module
Apalis iMX8X
- Up to 4x Arm® Cortex-A35 cores and 1x Cortex-M4 core
- NXP® i.MX 8QuadXPlus (i.MX 8QXP), i.MX 8DualXPlus (i.MX 8DXP)
- DDR3L RAM with ECC option
- Advanced hardware security and safety features
- On-board dual-band 802.11ac 2x2 MU-MIMO Wi-Fi and Bluetooth 5
Highlights
Up to four Cortex-A35 applications cores — the most power-efficient application Arm processor to support 32- and 64-bit code execution.
ECC (Error Correction Code) memory in the L2 cache, together with DDR3L RAM with ECC, helps to meet the industrial Safety Integrity Level (SIL) certification for critical industrial applications, such as programmable logic controllers (PLCs).
Support for hardware virtualization, Secure Boot, and the latest cryptography ensures that you can build a safe and secure system. The i.MX 8X SoCs are based on an advanced 28 nm FDSOI silicon process to increase MTBF and decrease soft error rates.
The heterogeneous multicore architecture allows the offloading of critical hard real-time tasks to the Cortex M4 or M7 processors for extremely low latency. Toradex provides tooling and FreeRTOS to simplify development. You can also use the asymmetric multicore architecture for a connected low power mode or to increase security.
Simplify your design with pre-certified wireless options, counting from the module to the antennas, to increase the predictability of end-device certification processes while enabling significant cost savings. The latest 802.11ac standard and support for multi-antenna setups contribute to a great out-of-the-box end-user experience. These are paired with Bluetooth 5 support to offer state-of-the-art integration for Bluetooth devices.
Each module comes with environmental test reports for vibration and EMI/EMC to give you peace of mind. These modules are built with highly reliable eMMC flash memory, and tools like the Toradex Flash Analytics tool allow you to monitor flash wear in a simple manner.
The Apalis iMX8X is pin-compatible with the other CoMs in the Apalis family. This allows existing Apalis-based products to easily scale and migrate to the new Apalis iMX8X. All of Toradex's Apalis Carrier Boards are compatible with the Apalis iMX8X. Extensive product documentation, developer support, service partners and third-party carrier boards build our strong Apalis ecosystem.
Operating Systems
Toradex offers free support and maintenance for embedded Linux and FreeRTOS on the NXP i.MX 8X-based Apalis iMX8X SoMs. This allows system designers to focus on the application only, instead of focusing also on the OS and low-level device drivers. Other OSs, such as Android and QNX, are supported by our partners.
Android on Apalis iMX8X is supported by our service partner Kynetics. An evaluation BSP is provided free of charge as a binary installer directly on Toradex Easy Installer feeds and in source code.
QNX is a microkernel-based OS primarily targeting safety-critical embedded systems. An evaluation image is provided for Apalis iMX8X directly from BlackBerry/QNX.
Ecosystem
Toradex Easy Installer allows you to install an OS in one click. It comes preinstalled from the factory, so all you need to do is turn on your on Apalis iMX8X and choose an OS!
The Apalis iMX8X provides high-performance graphics. Toradex partners closely with leading GUI technology providers to simplify the development process and make sure that hardware resources are utilized effectively.
Qt Framework
Get started with Crank StoryboardDiSTI GL Studio
The Apalis iMX8X is ideal for critical applications where safety and reliability are key. These are also the key focus areas for DiSTI’s GL Studio.
Get started with DiSTI GL StudioEdge Computing
AWS IoT Greengrass
AWS provides a wide range of services to help you build scalable industrial IoT solutions. AWS IoT Greengrass is a key tool that runs directly on the Toradex SoM. Currently AWS, NXP and Toradex collaborate closely.
Get started with AWS SageMaker NeoIndustrial Automation
CODESYS PLC IEC 61131-3
The Apalis iMX8X is a robust SoM, and its high performance is ideal for demanding industrial automation scenarios. CODESYS allows you to develop easily customized PLCs powered by a proven, long-lived software solution.
OPC UA is a standard technology widely used in industrial automation. The stack from Matrikon is a reliable, secure and platform-independent implementation that suits the Apalis iMX8X perfectly. You can integrate it yourself, or leverage the expertise of our partner, BE.services, to outsource integration.
Watch our webinar with BE.servicesCarrier Boards
Accessories
- Compatible with Apalis iMX8
- Cable length: 100mm
- Manufacturer: Unictron
- Manufacturer: Chang Hong
- Reference: DA-2458-02
- Cable length: 200mm
Roadmap
Hardware Roadmap
- Q4'20
- Q1'21
- Q2'21
- Q3'21
- Q4'21
- In Development
- Early access product
- Sample Product
- Volume Product Candidate
- Volume Product
Embedded Linux Support Status
Yocto Project BSP
PCIe | |
UART | |
USB Client / OTG | |
ADC (Analog Input) | |
Analog Audio Headphone | |
Analog Audio Line In | |
Analog Audio Mic In | |
DVFS | |
DVI | |
Ethernet | |
HDMI / DVI DDC | |
I2C | |
LVDS | |
Parallel RGB Display | |
PWM | |
Resistive Touch (4-wire) | |
RS485 | |
SDIO / SD Card | |
SPI | |
USB Host |
Yocto Project BSP
USB Host / Client Switch | |
JTAG Debug Support | |
Recovery Mode | |
S/PDIF | |
2D / 3D Graphics Acceleration (GPU) | |
Bluetooth (on-SoM) | |
CAN | |
Digital Audio (SGTL5000 via I2S) | |
GPIO Power-off | |
GPIO U-Boot | |
MIPI CSI-2 | |
MIPI DSI | |
Multimedia Playback (Gstreamer) | |
Parallel Camera | |
RTC | |
Suspend / Resume | |
Toradex Resistive Touch Screens | |
Watchdog | |
Wi-Fi (on-SoM) |
Upcoming feature, not tested
Buy Now
Unit Price$190.80$183.20$171.75$164.10
Coming soon
Unit Price$185.40$177.95$166.85$159.45
Coming soon
Unit Price$130.45$125.25$117.40$112.20
Coming soon
Unit Price$111.90$107.40$100.70$96.20
In stock
In stock
Quantity>0
Unit Price$245.00
In stock
Heatsink for Apalis iMX8 modules
Compatible with Apalis iMX8, Easily mounted to the Apalis Carrier Boards by means of 4 screws, Additional threaded holes available for attaching fan to the carrier board.
Unit Price$11.20$10.75$10.10$9.65
Limited stock
Power Adapter: 12VDC 30W with international plugs, Compatible with: Apalis Evaluation Board, Ixora Carrier Board, Colibri Evaluation Board, Iris Carrier Board.
Quantity>0
Unit Price$32.50
Limited stock
Cable length: 100mm, Frequency bands: 2.4 GHz and 5 GHz (dual-band), Manufacturer: Unictron, Reference: AA222 (H2B1PD1A1C385L), Range. Size: 40.0 x 6.0 x 0.5 mm.
Unit Price$3.90$3.00$2.50$2.20
Limited stock
Frequency bands: 2.4 GHz and 5 GHz (dual-band), Manufacturer: Chang Hong, Reference: DA-2458-02, Range. Size: 106.0 x 10.0 (max. diameter) mm.
Unit Price$5.60$4.20$3.55$3.10
In stock
Cable length: 100mm.
Unit Price$4.50$3.35$2.80$2.50
In stock
Cable length: 200mm.
Unit Price$6.70$5.00$4.20$3.70
In stock
Cable length: 200mm, Suitable for outdoor-usage (IP67).
Unit Price$9.65$7.25$6.00$5.30
In stock
