Colibri PXA310
Colibri PXA310 is a SODIMM sized computer module which is part of the Colibri product family. The product targets cost sensitive applications where connectivity and standard operating systems are essential. Colibri PXA310 is based on the Marvell XScale® PXA310 (Monahans) processor and runs at 624MHz. The module comes with a pre-installed and fully licensed WinCE 5/6 core OS. Linux is also available.
Colibri PXA310
Highlights
Video Capabilities - Marvell XScale® PXA310 with 624MHz
Colibri PXA310 is an SODIMM sized computer module are part of the Colibri family of modules. It is in use worldwide in many critical applications. It comes preinstalled with WinCE (Windows Embedded Compact). Its pin-compatibility with other Colibri modules featuring the latest SoCs from NVIDIA® and NXP® make it future-proof.
The product targets cost-sensitive applications where connectivity and standard operating systems are essential. Colibri PXA310 is based on the Marvell XScale® PXA310 (Monahans) processor and runs at 624 MHz. It features hardware video encoding and decoding and offers an interesting operating temperature range from -20 to +85 °C. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology.
Besides the internal Flash memory, there are additional interfaces available for data storage: USB-Memory Stick and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768. The modules can directly connect to a CMOS camera sensor.
In addition, Colibri modules offer 100 MBit Ethernet as well as USB host and USB device functionality.
Pin-compatible with other Colibri modules
The Colibri family of modules allows you to scale performance and price, and easily upgrade easily to the latest SoCs. Toradex WinCE (Windows Embedded Compact) OS and Toradex Software Libraries abstract the Hardware to make transition as easy as possible. To check if your carrier board is ready for your next Colibri module, use our quick and easy Pin-out Designer tool.
Design your own, use Toradex, or third-party Carrier Boards.
Professional development tools
Colibri modules come with a Windows CE operating system preinstalled and state-of-the-art development tools that allow for easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Latest Information on the Colibri PXA310
You can find the latest information on Colibri PXA310 at the Toradex Developer Center.
Operating Systems
Windows
Windows Embedded CE 6.0 is supported on Colibri PXAxxx modules. The development and maintenance is carried out in-house by Toradex. WEC allows you to use Microsoft .Net Compact Framework and Visual Studio.
Get Started
Features
FRONT
BACK
Colibri PXA310 624MHz
PN: 0005
CPU Name
CPU Type
CPU Clock
L1 Instruction Cache
L1 Data Cache
Marvell® PXA310
Intel XScale® Arm
624 MHz
32KB
32KB
RAM
128MB DDR (16 Bit)
USB 2.0
Ethernet
External Bus
I2C
SPI
One-Wire
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
1x Host (Full Speed)
1x OTG [Host (Full Speed), Device (High Speed)]
10/100 Mbit
16 Bit
1x
4x
1x
3x
1x
4x
Up to 92
4x (12 Bit)
1x 4 Bit
Graphics Controller
2D Acceleration
RGB
Resistive Touch
Camera Parallel Interface
Analog Audio Line in
Analog Audio Mic in
Analog Audio Headphone out
Integrated
Yes
1024 x 768 x 18bpp
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
Included Runtime License
Preinstalled OS
Size
Power Dissipation
67.6 x 36.7 x 6.2 mm
0.7 - 1.5 W
Intended Use
Minimum Product Commitment
2018
Carrier Boards
Learn more about SBCs and Carrier Boards
Colibri Evaluation Board
Datasheet
Iris Carrier Board
Datasheet
Viola Carrier Board
Datasheet
Aster Carrier Board
Datasheet
Supported Modules
USB 2.0
Ethernet
External Bus
I2C
SPI
UART
IrDA
PWM
GPIO
Analog Input
SDIO/SD/MMC
CAN
JTAG
Entire Colibri Family
4x Host, 1x OTG/Client
10/100 Mbit
Up to 32 Bit
4x
4x
2x RS232, 1x RS422/485
1x
4x
up to 158
4x
1x 4 Bit
1x
Yes
1x Host / 1x OTG
10/100 Mbit
1x
1x
3x RS232
4x
up to 26
4x
1x 4 Bit (microSD)
2x Host, 1x Client (Shared)
10/100 Mbit
1x
1x
3x /
3x TTL
4x
up to 35
4x
1x 4 Bit (microSD)
10/100 Mbit
1x
1x
2x TTL, 1x USB-UART
4x
up to 39
4x
1x 4 Bit (SD/MMC)
Yes
Switches
LEDs
6x
4x
up to 3x
LVDS
HDMI
VGA
RGB
Capacitive Touch Interface
Resistive Touch
Analog Audio Mic in
1x Single Channel
1x (Through DVI-I connector)
1x
1x (18 Bit/24 Bit)
Adapter required
4/5-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x Dual Channel
1x (18 bit)
Yes
4/5-wire
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (18 bit)
Adapter required
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
1x (Shared with RGB)
1x (18 bit)
Yes
4-wire
1x
1x (Stereo)
1x (Mono)
1x (Stereo)
Type Specific Board Connector
USB-to-RS232 Transceiver
RTC on Board
Included Accessory
1x
1x
Mating Power Plug (for X33)
24-way FFC 100mm (for X6)
Yes
1x
Mating Power Plug (for X17)
24-way FFC 35mm (for X4)
Yes
1x (*Not Assembled) /
1x
Yes
1x
1x
Yes
Supply Voltage
On-Board Power Supplies
Size
Temperature
7-27V DC
5V 5A
3.3V 5A
200 x 200 mm
6-27V DC
5V 5A
3.3V 5A
100 x 72 mm
-20° to 85° C
5V DC +/- 5%
5V (External)
3.3V 3A
74 x 74 mm
-40° to 85° C
5V DC +/- 5%
3.3V 3A
100 x 80 mm
-25° to 85° C
Intended Use
Pricing
For Evaluation/Development
1 : $220.00
For End Products
1-99 : $73.50
100-249 : $70.55
250-499 : $66.15
500-999 : $63.20
>999 : RFQ
2030
For End Products
1-99 : $32.50
100-249 : $31.20
250-499 : $29.25
500-999 : $27.95
>999 : RFQ
2034+
1 : $64.90
Accessories
Colibri Fasteners
LM816 USB WiFi
Analogue Camera Adapter
Have a Question?
