Colibri PXA320
Colibri PXA320 is an SODIMM sized computer module which is part of the Colibri product family. Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology. The module comes with a pre-installed and fully licensed WinCE 5/6 core OS. Linux and Android are also available.
ハイライト
Ready for Takeoff - Marvell XScale® PXA320 with 806MHz
Colibri PXA320 is an SODIMM sized computer module which is part of the Colibri product family. Colibri PXA320 is based on the Marvell Arm® XScale® PXA320 (Monahans) processor and runs at 806MHz. The processor's power consumption is optimized using the Intel Wireless Speedstep® Technology. Colibri modules feature state of the art technology, aiming at low power systems that require high CPU performance. They also provide all the interfaces needed in a modern embedded device.
Besides the internal Flash memory, there are plenty of interfaces available for data storage: USB-Memory Stick, Compact Flash / PCMCIA and SD Card.
Colibri modules provide glueless connectivity to passive and active LCDs with resolutions of up to 1024x768, as well as 4 and 5-wire resistive touch screens. An integrated 16 bit stereo codec allows to play and record audio. Colibris can directly connect to a CMOS camera sensor.
In addition Colibris offer 100 MBit Ethernet as well as USB host and USB device functionality.
Flexibility and Scalability
Colibris can be scaled to meet specific cost requirements.
The entire CPU bus is available for custom extensions, such as special interfaces for high bandwidth applications.
Industrial Temperature available
Colibri PXA320 IT is a special version which meets the stringent requirement of industrial temperature range (-40 to +85 degree Celsius).
Colibris come with a pre-installed Windows CE operating system and state of the art development tools that allow an easy customization of the system to make it fit specific needs (e.g. LCD settings & timings, integration of customer software and the auto-start option at startup).
Latest Information on Colibri PXA320
オペレーティングシステム
Windows Embedded Compact
キャリアボード
詳細を見るアクセサリー
